An EF & RF mount hybrid mirrorless camera in the works [CR2]
EOS 1D MK II
7,826
457
We have been told a couple of times now that a “pro” EOS R mirrorless camera that is in the works will have some kind of a hybrid EF/RF lens mount. So this basically means that you’d be able to mount both types of lenses without the use of an adapter.
We were also told that this was being developed for the “EOS-1 style EOS R camera”, which would make a lot of sense. As I don’t believe the reduction of size for an “EOS-1” style mirrorless camera is all that important.
This is definitely a bit of a strange rumour, but if Canon could pull this off, it would be great for Canon shooters.
We’ll have some more information on this soon.
Continue reading...
Reactions: fox40phil
uri.raz
Jan 5, 2016
175
114
*Something* has to gap the 26mm difference.
Assuming this rumor is true, an adapter is detachable, the only option I can think off is a collapsible mount - a tube that can be pushed in & pulled out as needed. Somehow, I doubt we're going to see this in a pro camera.
Joe Subolefsky
Sep 8, 2019
17
69
That would make a lot of sense given the two new Big Whites 400 & 600 III's most pro sports and wildlife shooters use just came out this year.
Optics Patent
Former Nikon
Nov 6, 2019
134
76
My patent pending alternative is to offer the big white lenses with visually integrated rear mount portions that remove (only when lens is detached) for use on EF. RF mount users might be offered TC adapters as substitute upgrades.
At very least if I’m going to drop $12k on the 400 III for an R mount I’d like an included adapter in matching white.
Reactions: FramerMCB
IcyBergs
I have a Sony...TV
May 31, 2016
34
71
If there is any truth to the rumor then I believe that the niche lenses (specifically big whites) won't be coming to the RF mount any time soon.
criscokkat
Sep 26, 2017
313
286
Madison, WI
I predicted the moving sensor more than a year ago to explain the 'sexy' mount solution in pre-R rumours.
Such a system can't be done without a sensor on rails.
On the other hand, why on earth would Canon do that now, after the EOS R release?
This might work well with a video centric camera. The sensor position could be adjusted to any location needed. You could potentially also have a PL mount adapter that was smaller and have the sensor change position to accommodate that.
KrisK
Jun 8, 2013
62
12
You've never used a collapsible thermos? Heck, you could probably shoot around corners with one of these.
andrei1989
Sep 1, 2014
383
62
30
aren't the two mounts phisically incompatible? different diameters and distances (not flange distance)
can one actually mount an EF lens on an R body without an adapter? not use the lens, simply mount it
YuengLinger
Dec 20, 2012
2,741
891
Southeastern USA
Interesting. I know that balancing some of the EF lenses on the R, such as the 70-200mm f/2.8L IS II is not so fun when taking shots in portrait/vertical orientation. Part of this is because the adapter throws the lens more off balance. I wonder if a hybrid mount might address this...but the spacing provided by the adapter has to be made up somewhere?
unfocused
EOS 1D MK II
5,144
1,626
66
Springfield, IL
www.mgordoncommunications.com
It will be interesting to see if this makes it to market. It would certainly simplify things for people using both DSLRs and Mirrorless at the same time.Also indicates that the EF line is far from dead. Perhaps there is still hope for an R to EF adapter down the line. True interchangeability would certainly be a plus.
