An RF mount L macro lens will be announced alongside the high-megapixel EOS R camera
Canon EOS 40D
10,808
3,162
We’re told that Canon will announce a new and “unique” RF mount L macro lens alongside the high-megapixel EOS R camera sometime in early 2020.
The source wasn’t sure what will make the new macro lens “unique”, but did say they were told that it would be faster than f/2.8.
In the past, we have heard that Canon is working on some kind of zoom macro, but we aren’t sure if that’ll be a feature in a new standard type zoom lens, or an actual 1:1 macro lens.
Note: The image for this article is the EF 100mm f/2.8L IS
Continue reading...
SteveC
R5
2,677
2,589
A tilt macro would be unique. Or maybe low hanging fruit, like a full-frame macro with a built-in LED ring light (as found on EF-M and EF-S macro lenses).
That reminded me of a thought I had.
Would it be feasible to make an EF-RF (or EF-M) adapter that had the tilt-shift mechanics in it?
If so, basically ANY EF/EF-S lens could become a tilt-shift lens on an R or M series camera.
Sharlin
1,415
1,433
Turku, Finland
Possibly, but TS lenses aren’t just normal lenses with a fancy mechanism. They have an extra large image circle in order to be able to fill the sensor even tilted/shifted. But an FF lens on an M body, or R body in crop mode, could work.
31,182
13,030
Do you mean tilt-shift? There are already 3 TS-E macro prime
I’m aware of them, thanks (and although I don’t have the new TS-E lenses with 1:2 max mag, I have the 17 and 24mm TS-E lenses).
No, I mean tilt only. Combined with 1:1 macro that would be unique. From a purely macro perspective (pun intended), shift doesn’t offer much but tilt can be very useful. I suspect that by sticking to tilt, Canon could both allow higher max magnification and a greater degree of tilt (the latter would be important if the lens has a longer focal length, which I think is likely given that there’s already an RF 35mm macro).
31,182
13,030
Possible, but keep in mind there’s only 24-26mm / 1” to work with. The TS mechanisms on the current lenses are much longer than that. A tilt-only or shiFt-only adapter would be straightforward. That assumes a lens image circle large enough, as mentioned above, so an adapter for EF lenses to an M body would make more sense. Well, more sense from a technical standpoint, the problem is they would not make much sense from a marketing standpoint, IMO.
31,182
13,030
Is a larger image circle necessary for a tilt?
For a tilt lens, yes. That’s one major difference between TS lenses and the old cameras where the film back did the moving – a tilted image plane (sensor/film) will remain within the size same image circle as the default neutral angle, whereas tilting the lens will cause clipping if the image circle is not larger than what is needed to cover the sensor. It’s progressive, so the more tilt the lens has, the bigger the image circle needs to be.
dancan
R5
Jan 8, 2015
30
35
Possible, but keep in mind there’s only 24-26mm / 1” to work with. The TS mechanisms on the current lenses are much longer than that. A tilt-only or shit-only adapter would be straightforward. That assumes a lens image circle large enough, as mentioned above, so an adapter for EF lenses to an M body would make more sense. Well, more sense from a technical standpoint, the problem is they would not make much sense from a marketing standpoint, IMO.
I take the shit-only adapter;);)
  • Haha
31,182
13,030
A new 1-5x macro, but with a ring light at the end. That would be pretty sick.
Yeah, but not unique.
Well, sort of unique because the linked lens has three LEDs not a ring and is 4-5X, not 1-5x.
168
126
So then, unique. Also, that's still for EF-M. Not RF. You'd have been better pulling up a link for Canon's 1-5x EF lens (which is fantastic and relatively cheap).
31,182
13,030
Good point, I forgot it was EF-M and neglected to check.
Thanks for the correction!
I have the MP-E 65. Not sure I’d actually want a ring light, too flat. The TwinLite does much better for adding depth to my shots (I had both MR and MT, didn’t keep the former).
