Confirmation: EOS RP charging (What I successfully tested so far)
Bennymiata
Providing your charger or battery box has has USB-C PD charging, it will charge an R or RP.
However, the rate the cameras charge is only 5v at under 2amps or 10 watts which is what most phones charge with normal charging.
PD charging does allow for much faster charging (60 watts is common), so I don't understand why the charging on the R and RP is so slow.
15,699
874
I have the Canon charger that came with my Grip, and a Anker PD single port charger. I can't tell any difference in the charging. It is slow, charging generates heat which is not good for a camera.
koenkooi
Feb 25, 2015
741
499
I suspect heat is the issue, Canon seems to be very adverse to heating up cameras as much as the competition does. And related to that, batteries don't get destroyed as fast when being charged slowly.
mangobutter
Dec 11, 2014
128
33
www.e46mango.com
I suspect no matter what, the camera is smart enough to not let itself be charged at any rate which is adverse to its functionality or well being. My RP seems to charge reasonably quick when plugged into the iPhone charger. Then I have the other battery charging in its Canon charger.
cycomachead
Jan 7, 2012
24
3
Has anyone found non-Canon LP-E6N compatible batteries for in camera charging? All of mine show to the camera as "LP-E6" and as such won't charge.
Just to confirm as well: MacBook Pro USB-C chargers work well, and I have an Anker 5 port USB / USB-C combo charger. The USB-C port works well, but naturally USB-A to USB-C cables do not work. (No PD support.)
I was always skeptical of in-camera charging, but since it's USB-C, I think this will make a good night time 2nd/backup charger when traveling, since I'll always have a USB-C brick with me,
tron
Nov 8, 2011
4,441
701
Not RP but R: I have used 4Smarts 20000mah (the one capable of providing 65W for type-c and 18W for USB-A connections = total 83W successfully) Also a PD capable type-c 4smart car adaptor worked fine. The big battery back was about 750gr so rather heavy for my bag so I got a "no-name" 10000mAh (I wanted it for the next day) AWEI with PD which also worked fine! (The funny thing is that It turned out to have no need to use it, I also had some spares LP6N batteries, so rather overkill but it was a 20euro overkill situation so no big deal).
Ramage
Aug 27, 2019
54
44
Not a big fan of charging in Camera so I use https://www.amazon.ca/gp/product/B072BBWHRK/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1 with my Anker PD 1000 and have had good results. The batteries that came with the charging platform seem to work fine but again I am not a fan of 3rd party batteries and never leave them in the Camera or use them other than in an emergency. Note I have never had a bad experience with 3rd party batteries just a personal quirk, funny I use a bunch of different brands of Sony F type batteries and never think about it at all:)
My goal is simply to be able to charge all my batteries with a USB power bank and this fits the bill.
tron
Nov 8, 2011
4,441
701
Coincidentally I have bought it recently but I haven't fully tested it apart from the fact that both slots work. It is a slow charger but slim at the same time so I bought it for travelling without a car as a second charger in place for my bigger double one (second charger) that uses mains and car battery.
Ramage
Aug 27, 2019
54
44
Coincidentally I have bought it recently but I haven't fully tested it apart from the fact that both positions work. It is a slow charger but slim at the same time so I bought it for travelling without a car as a second charger in place for my bigger double one (second charger) that uses mains and car battery.
Yeah it is bit slow but my goal was for Camping and extended times where I am just using Solar panels to charge my power packs. Works well enough to keep me powered:)
