Current unreleased Canon gear from certification agencies
EOS 1D MK II
7,448
240
Below are unreleased Canon cameras that have appeared at certification agencies. We expect the PowerShot G3 X Mark II and PowerShot G7 X Mark III to be amongst these cameras. There could also be a follow-up to the EOS M5 and the EOS M100 as well.
PC2355 – (Possibly the PowerShot G3 X Mark II)
Digital camera
made in Japan
Equipped with Wi-Fi and Bluetooth 4.1
PC2358 – (Possibly the EOS M5 Replacement)
Digital camera
Battery: LP-E17? (7.5 Wh)
PC 2366 – (Possibly the PowerShot G7 X Mark III)
Digital camera
Wi-Fi, Bluetooth 4.2 loading
Battery: NB-13L
See downloadable WM601 PDF for details on this camera
PC2367 – (Possibly the EOS M100 Replacement)
Digital camera
Battery: LP-E12 (7.2 V 875 mAh)
Continue reading...
rrcphoto
Jun 20, 2013
2,505
147
crazyrunner33
Nov 4, 2011
235
72
Correct, the number which is the same as the 24.1 megapixel M50 in 4:3 mode. The medium and small sizes are also identical.
Edit: the .1 for 24.1 megapixel comes from the unused pixels(6012x4008 vs 6000x4000 in the final image)
Woody
1,120
30
I am curious about the EOS-M5 MkII.
But will only upgrade if the improvements are substantial...
Apr 17, 2019
Ah a shame it's LP-E17, was hoping for a larger LP-E6 aps-c mirrorless M mount since can isn't doing an aps-c R varient.
The small size just seems restrictive for a top end EOS M.
padam
Aug 26, 2015
528
182
With the introduction of the EOS RP using the same battery, it doesn't make sense both in terms of size and extra cost. The original M5 body only MSRP was close to 1000$, maybe this time it might be a little lower, like 900$ or so.
One question mark is: will it keep the existing design or switch to a fully articulating screen?
Hector1970
Mar 22, 2012
1,013
135
I haven't really considered buying an EOS M but its users seem to be very happy and it sells well in Japan.
I find it an oddity.
To me it felt like a stop gap until they had an EOS R APS-C version (which may never come now unless they do a 7D version). It's perhaps been more successful than Canon expected or planned for.
The EOS M has a nice range of lens but (I'm not sure about this bit) is not compatible currently with EOS R lens.
This has been one of the advantages of the EF system that all non EF-S lens worked on the APS-C camera.
I'm an Olympus user too and the lens are great but the micro 4/3 sensor can only be so good.
APS-C would have been in retrospect a much better sensor size for Olympus to build their system around.
I think if the EOS M was R lens compatible I'd be more open to buying one.
As it stands I wouldn't go down the route of having a M set of lens incompatible with other cameras.
Yes I could use EF lens with an adapter but it would I expect be quite unbalanced with L lens.
Quarkcharmed
EOS 5DMkIV
Feb 14, 2018
303
141
Australia
www.michaelborisenko.com
[QUOTE="Hector1970, post: 772382,
[/QUOTE]
Not compatible currently and will never be. Also M lenses will never fit the R mount. In theory an adapter is possible that has glass inside, but such an adapter will affect the quality badly.
Reactions: crazyrunner33
blackcoffee17
Sep 17, 2014
126
97
I really hope the M5 II will be something like a X-T3, a bit better built than the current M5.
It's disappointing they decided to use the same LP-E17 battery. Will be another camera with 200 shots
battery life.
BillB
May 11, 2017
899
124
Canon seems to have made a clear choice not to have lens compatibility between the M and the R systems. The M lenses are relatively inexpensive and slow, a sign that price plays a big role in Canon's thinking about the M line.
Woody
1,120
30
They offer the 32mm f/1.4 and 22mm f/2.... So lens speed is not necessarily slow.
Rather, I will describe M lenses as small, lightweight and relatively inexpensive.
If Canon comes up with a RF-mount APS-C camera, the lenses will be larger and more expensive. They'll lose customers like me.
