HTML:
<p>You can get the Rokinon 14mm F2.8 AF Wide Angle for $649 (Reg $799) today only.</p>
<p class="fs16 OpenSans-600-normal product-highlights-header">Product Highlights</p>
<ul class="top-section-list" data-selenium="highlightList">
<li class="top-section-list-item">EF-Mount Lens/Full-Frame Format</li>
<li class="top-section-list-item">Aperture Range: f/2.8 to f/22</li>
<li class="top-section-list-item">One Extra-Low Dispersion Element</li>
<li class="top-section-list-item">Two Aspherical and Four HRI Elements</li>
<li class="top-section-list-item">Ultra Multi-Coating</li>
<li class="top-section-list-item">Autofocus, AF/MF Switch</li>
<li class="top-section-list-item">Weather-Sealed Construction</li>
<li class="top-section-list-item">Rounded, Seven-Blade Diaphragm</li>
</ul>
<p><strong><a href="https://www.adorama.com/rk1428afca.html?emailprice=t&utm_source=rflaid64393">Rokinon 14mm F2.8 AF Wide Angle $649</a></strong> (Reg $799)</p>
