Extreme Macro shots with stacked lenses
Last fall I came across some super amazing macro shots of snowflakes up close. I instantly fell in love with the concept and started working on learning how to do it myself. With a reverse stacked lens, your magnification is a divisor of the front lens and the reverse stacked lens. So, for higher magnification you want a larger lens connected to the camera and a smaller lens reverse stacked on the front.
I'm using a Canon 70-200mm f/2.8 lens, a 1.4x III extender, a reverse lens adapter ring and a Nikon 24mm f/2 AIS lens. This gives me a magnification of 280 / 24 = 11.66x! For light, I'm using a 580EX Speedlight connected via an ETTL cable so I can position it however I need to. This combination is really dark to see to focus, so sometimes I'll turn up my cell phone brightness. I'm really just getting started, my first few photos were done hand-held, trying to position my cell phone light and the flash while hand holding the camera and moving in or out to focus. This is the method I used last night when we got a little bit of snow and ice in NC. I got these shots from the top of our garbage can:
Frozen Crystals by yorgasor, on Flickr
_MG_1129 by yorgasor, on Flickr
This morning I wanted to get something a little more repeatable and stable, so I built my first round of a macro table stand. I ran an 8" bolt through a 2x6" board, which then attaches to a small table on 3 legs with a nut embedded into the table. This allows me to raise and lower the table by spinning it. I also now just need one hand to hold the flash, and the other to press the shutter button.
The drawback to this approach is that the item I want to focus on spins around when I'm trying to raise or lower it. The threads on the bolt are also rather thick, so the top table wobbles back and forth in the nut. I can try adding another nut for stability, but I think I need to device a method of raising and lowering the top table without having to spin it.
Here's a photo of my new stand:
Ah, now that's the kind of photo I'd like to be able to take. Unfortunately, the amount of snow that falls here is pretty minimal, and it almost never sticks :(. I don't have a lot of opportunities to practice my technique. I'm not sure if I'll get another opportunity this year.
I'm assuming the CA is an artifact of the harsh, direct flash. I see something similar on the dime I've been using as my test subject so far. I'll be playing around with lots of different lens combinations to find what gets me the best results. I'd like to try some photo stacking to get a larger amount in focus on objects, but I'm afraid that might be tricky with the rotating table (it might work if I also rotate the image and line things up in PS). I'm also building my own light stands, so hopefully I can work with better lighting.
I've got a long journey ahead of me as I work on perfecting my technique.
It seems to me that vintage glass is causing the pink/green LOCAS. If you stop to think, there is a lot of glass surfaces (some uncoated) causing aberrations. Here in my country (Brazil) do not have snow, so I do not know the size of snow crystals. However, as compared know of a photographer who made ​​a Gadgety to photograph the grains of sand on the beach, and he discovered colors, and shapes that never imagined seeing a seemingly monochromatic sand. Even invisible to the naked eye molluscs. The equipment of him consists in: 5D​​mark ii + 180mm L + extension tube crafted with PVC piping (30 cm) + support for camera and flash with adjustable crank gears. As it is necessary to bayonet adapters, can avail to use the bayonets of cheap extension tubes and macro lenses like Nikon 200mm F4.
Nov 9, 2013
183
11
805
9
neuroanatomist said:
Nice setup! Lots of LoCA in your snowflake images, though. :(
Here's a snowflake shot I took few weeks ago, with the MP-E 65mm at 5x magnification and the MT-24EX flash, handheld.
I have the MP-E 65mm but could not possibly hand-hold it at 5x, even with my ring flash. What kind of shutter speed were you getting with this shot?
4,932
1,608
My guess would be 1/250s, which is the syncspeed of the 1dx. Kill ambient and the flash freezes the motion, and probably melts the snow flake, lol.
Incredible shot Neuro!
surapon
80% BY HEART, 15% BY LENSES AND ONLY 5% BY CAMERA
Aug 2, 2013
2,957
4
74
APEX, NORTH CAROLINA, USA.
Thanks you, Sir, Dear yorgasor
Great setting and Great Extream Macro Photography.
Good night.
Surapon
surapon
Aug 2, 2013
2,957
4
74
Thanks you, Sir, Dear Teacher Mr. neuroanatomist.
Great Extream Macro Photo from MP-E 65 mm. Your Photo make me want to try my MP-E 65 mm. too.
Thank you, Sir.
Surapon
mrzero said:
You might consider using the tripod collar on that big 70-200. if your rotation of the table is small enough, you could even use the tripod collar to rotate the camera to match. And you might be able to use a wired or wireless remote to trigger the camera with the same hand you are using to hold the flash.
I do have the wired remote and the tripod collar. I could try spinning them both to match, but that's a lot of precision to get just right. I'll have to see what other designs I can come up with to get things just right. What would be really nice would be to have an external display so I can fiddle with the table and see what the camera sees at the same time. With such a long macro solution, it's hard to do both at the same time.
Consider getting a cheap macro slider to use to focus.
You can tether the camera to a laptop via USB and Canon utilities and see the live image as well as release the shutter when it looks right. The image can be brightened as well, so you can see it better.
31,220
13,081
Thanks, Viggo!
You're correct - 1/250 s, f/14.
TheJock
Oct 10, 2013
555
Dubai
A technique I tried (which worked well for me) was to use my best sturdy tripod to hold all the camera gear, and one of those little cheap aluminium tripod’s that have the wind up centre column as the platform, this way you have full control over winding up and down (I found I could even do it while focusing through the viewfinder), it worked well with macro as the items are light weight and don’t send the cheap tripod spinning back down!!
You're right, if I want to do photo stacking to improve my depth of field, I'm really not going to be able to build something any better than a good macro slider. That really will solve all of those problems.
And how did I miss that you can hook up the 5D3 to a laptop and get a video feed from that? That's a brilliant solution and will definitely come in handy when I want to do some more self portraits. It's really tricky to get the focus and positioning just right when you're trying to work both sides of the camera!
Thanks for the tips! When I'm done, I plan on compiling all this information into a good blog entry or something. I really got hooked on it when I saw the Russian guy's snowflakes and tried reading all the information about it. I ended up getting snippets of hints here and there but never all the information I needed in one place.
31,220
13,081
K-amps said:
What software's (including ML) do focus bracketing? I'd like to do this for Macro shots. I have Macro rails, but the tiniest of lateral movement on the tripod could affect the shot. However Automatic focus bracketing could help eliminate that one variable.
Helicon Focus does, and I think Zerene Stacker does also. However, you're trading one variables for another - macro lenses focus breathe (almost all lenses do, except cinema lenses which is one reason they cost tens of thousands). Focus breathing changes your magnification, real focal length, and framing - if your stack is deep enough, you'll notice it.
Probably the best solution is a macro rail with a stepper motor, like the Cognysis StackShot.
K-amps said:
What software's (including ML) do focus bracketing?.......
If you've got an Android phone or tablet.......
https://play.google.com/store/apps/details?id=eu.chainfire.dslrcontroller
It doesn't do focus bracketing per se, as far as I've explored it, more like focus stepping.
You set the step sizes within certain limits, you set the range limits. Each focus step can also be exposure bracketed at the same time.
The app has its own web site at..
http://dslrcontroller.com/
I've found that that site pretty much has all the help and support you'll readily find.
There is a support forum thread at.......
http://forum.xda-developers.com/showthread.php?t=1202082
This single thread currently runs to over 300 pages with over 3,000 posts, good luck finding answers there.
No matter that the thread is so overwhelmed, the site is pretty comprehensive.
I'm running the app on a Samsung Galaxy S4, it also runs on my two older phones though it rather overwhelms the oldest phone.
I'm using it to tether to my 6D.
Tried using Wi-Fi, found it very erratic regarding the stability of the connection, I found it essentially useless over Wi-Fi. I suspect it's an issue with the 6D's Wi-Fi implementation.
Having given up on Wi-Fi, I stepped up to a cable connection which is rock solid and dependable. S4 as many others use an USB OTG (On The Go) Host cable adapter which go for less than $5 U.S. on Amazon.
The app does way more than I could have ever imagined prior to trying it, I now consider it a Must Have accessory.
I'm so impressed with this app/camera combination, I'm considering buying a 7” or 10” tablet to run essentially just this app.
Before you click the buy button, do read the full description, especially read the devices page at...
http://dslrcontroller.com/devices.php
make sure your devices are listed.
If you currently have your camera set to back button focus, you'll need to reset back to focus activation on the shutter release button as when new, otherwise there will be no focus control from within the app, not much point in that.
On my 6D, I set up Custom shooting mode C1 just for this app.
Ah, Neuro, happy you showed up!
….. However, you're trading one variables for another - macro lenses focus breathe (almost all lenses do, except cinema lenses which is one reason they cost tens of thousands). Focus breathing changes your magnification, real focal length, and framing - if your stack is deep enough, you'll notice it....
I had wondered about focus breathing, specifically if maybe the term was incorrect and if maybe Focal Length Breathing might be a more accurately descriptive term.
I have seen write ups where this was apparent in the results even though glossed over and un-commented upon by the author.
Specifically, the target subject was a quarter, viewed on an angle.
As you'd expect, the quarter should appear oblong when viewed at an angle and it did indeed.
In the focus stack example, the near edge was fairly circular when the near edge was the focus point, the far edge was visually drawn out.
Once the focus point reached the far edge, the far edge appeared somewhat more circular, the near edge became drawn out.
Once the set of frames had been combined, the end result looked to me, rounder overall, though not completely round.
I get a headache trying to wrap my head around the following concept, I certainly have no idea if it is true or not, maybe you know?
Assuming a fixed focal length as with a prime, is the focal length true only in the center of the area in focus? Is there focal length drift away from that center that is of absolutely no consequence when focusing at a distance but only becomes obvious and significant when focusing very close?
IF the above is true, again, I have no idea, then a completed focus stacked set should have a proper perspective for the focal length used all the way across the final image. Seems to me that this would be a desirable end result.
http://www.cognisys-inc.com/stackshot/stackshot.php
Oh my, that is beautiful stuff. For what is is and does, the price looks downright reasonable, possibly justifiable.
BUT, from the few railed stacks I've seen, if there is anything in the background, background objects get totally borked by the rail process, similar to long exposures while zooming.
As long as the background is clear, no problem.
Now, if my focal length drift concept above is true, would there be any significant difference in the end result between marching the focus point/plane across the subject using the lens' focus compared to marching the focus point/plane by moving the entire lens/camera assembly?
197
