Favorite Method to Clean Sensor
digigal
283
586
Thanks for your replies. I've used the Pen as well (Artie Morris used to recommend it when he was shooting Canon). Have never tried the Arctic Butterfly Brush. When I took my IR converted EOS M3 in to be cleaned the camera store was totally down on PEC pad/liquid cleaners and Pen cleaning. Not sure what they use. Maybe it's the Palmolive method:eek:. It's my little mirrorless (M3, and Olympus OMD EM-5) that I converted to IR that I have the problem with because they have to disable the manufacturer's sensor cleaning mechanism when they do the IR conversion so any dust that enters when changing lenses stays there. I rarely have problems with my 7DMKII or the EOS M5 that is not converted.
A air blower helps with the more recent Canon sensors, dust doesn't stick to them as well. I will wet clean a sensor if it has gunk stuck to it, but thats not happened to me for several years now. Canon always uses the pec pad method, no liquid. This has resulted in several complaints about sensors still dirty after cleaning but thats their method. I bought some pec pads, but they leave the sensor dirtier that before, obviously bad ones. I've also had bad pre moistened sensor swabs, so I start with dry ones and add a tiny amount of eclipse.
I'd get a Artic Butterfly if I needed frequent cleanings.
The couple times I have actually needed it I went to my local camera repair shop. It does cost a bit but it is done so rarely that I feel it's worth the money not to risk damaging anything myself.
Thats a good idea as long as they stand behind their work. I've read horror stories about inept camera shops, even Canon damaging sensors and refusing to acknowledge the issue. I'm mechanically oriented, and will attempt to repair virtually anything, I've a huge assortment of specialty tools. I'm losing my ability to do fine work as I am getting up there in age, but I still do a fair amount, just slower now.
