FINAL SPECIFICATIONS for Medium Format Sensor 8K/50.3 Megapixel Combined Stills/Video Global Shutter Mirrorless Camera !!!!
HarryFilm
Jun 6, 2016
567
93
PART 1:
Well..... Canon BETTER get Cookin' on a DCI 8K camera cuz
HERE IS THE FINAL BURNED-INTO-STONE SPECS for the one
coming out sooner than you think:
The manufacturer was CONVINCED to include all the following features
by a dedicated team of professional photographers/videographers and by
the leadership of the codec programmers and camera systems designers
to help Pro-level Still Photographers Cinematographers and various VFX,
Engineering and Science personnel make their lives so much easier!
This is a NEW GENERATION Image Capture System
that goes WAY BEYOND what it available today!
NEW CAMERA NEWS FLASH !!!!!!
BRAND NEW Medium Format COMBINED Stills/Video Camera coming
sooner than you think from a famous worldwide multimedia company:
1) IP-68 ruggedized Magnesium Alloy Body Medium Format camera:
a) Mirrorless Combined Stills/Video Camera body with a custom
in-house built 50.3 megapixel (8192 x 6144 pixels) 4:3 aspect ratio
(Anamorphic-friendly) 70mm Global Shutter CMOS sensor
(i.e. No Jello Cam Anymore!)
Sensor Type: Global Shutter CMOS
Sensor Area: 56mm by 42 mm (70mm diagonal) 4:3 aspect ratio
Photosite Size: 6.8 Microns
Capture Pattern: Bayer
Native Resolution: 8192 x 6144 photosites
Lens Mount Type and Diameter: User-Swappable PL-Mount
and the other consumer-level still photo/video lens mount is Still A Secret!
b) ADC/DSP Type: 32 bits ADC where each colour sample is
Nyquist downsampled to 16-bits per RGBA/YCbCrA channel
for recorder side digital signal processing.
c) Alpha Transparency and/or Distance Channel sampled via
secondary RF and IR emitter/receiver reflectometry at 32-bits
per sample at input using Z-pattern scanned array reflectometry
with output samples downsampled to 16 bits or user-selectable
sample size. (i.e. used for VFX and Greenscreen personnel)
d) Output Pixel is user-selectable RGBA or YCbCrA type at 16-bits,
14-bits, 12-bits, 10-bits or 8-bits per channel at 4:4:4, 4:2:2 or 4:2:0
colour sampling.
User-selectable Rec.2020 and Rec.709 colour spaces and sampling.
e) Has very low-noise with extreme low-light sensitivity (ISO 204,800 extended
up to ISO 409,600) and an ASTOUNDING 17 Stops of dynamic range
(at 64-bit RGBA/YCbCrA colour) and very high signal-to-noise ratio (144 db)!
What THIS camera sees at ISO 51,200 is equivalent in low-noise and
colour accuracy as what the Canon 1Dx Mk2 sees at ISO 12,800 so
we are talking EXTREME low noise, great colour, sharp edges and
BEAUTIFUL Beyond-HDR photos and video.
2) Still Photo and Video Frame Specifications:
a) Still Photo Capture:
- 60 fps Burst Rate 8192 by 6144 pixels (50.3 megapixels) 64-bits per pixel
RGBA/YCbCrA (up to 16 bits per colour and alpha or distance channel) that
is user-selectable 16-bits, 14-bits, 12-bits, 10-bits, 8-bits per channel plus
custom pixel sample bit-widths. Output files are RAW, JPEG, HEIF, BMP, TIFF
- 120 fps Burst Rate 6144 by 4608 pixels (28.3 megapixel) up to 16 bits per channel
(User-selectable full frame capture and downsample or sensor crop mode capture)
- 240 fps Burst Rate 4096 by 3072 pixels (12.5 megapixel) up to 16 bits per channel
b) Video Capture: (User selectable) from:
- 120 fps, 100 fps, 60 fps, 50 fps, 30 fps, 25 fps, 24 fps DCI 8k video (8192 x 4320 pixels) 4:4:4:4 RAW or InterFrame or Intraframe compressed.
- up to 240 fps DCI 4k video (4096 x 2160 pixels) 4:4:4:4 RAW or InterFrame or Intraframe compressed.
- up to 1000 fps DCI 2k video (2048 x 1080 pixels) 4:4:4:4 RAW or InterFrame or Intraframe compressed.
- up to 4000 fps DCI 1k video (1024 by 540 pixels) 4:4:4:4 RAW or InterFrame or Intraframe compressed.
- Multiple UHDTV, HDTV and Computer-friendly frame sizes and integer + fractional frame rates.
c) All output resolutions and colour sampling can be 4:4:4:4 FULL RAW or 4:2:2/4:2:0
at 16 bits, 14 bits, 12 bits, 10 bits and 8 bits per RGBA/YCbCrA pixel channel.
d) Has User-selectable Time Lapse intervals from X-frames per second to many minutes or hours per frame.
e) Records multiple files at same time with varying/user-selectable recorded frame rates
and aspect ratios, multiple file container formats including H.265/H.264, AVI2, MOV, MP4,
JPEG/HEIF/BMP/TIFF and legacy MPG/MPEG-2/MP3 video and audio codecs.
Full Resolution Video/Audio/Metadata can be output to SSDs and/or sent out
to high-speed ports and the lower resolution Proxy Video/Audio/Metadata
can be sent to CFe Cards and/or External recording devices and connections.
f) Has continuous pre-roll where imagery is continuously captured within a 15 second
rotating 8K buffer or a 60 second rotating 4K buffer for instantaneous capture of
stills and video once record button is pressed.
3) Shutter Type: Global Electronic Shutter at up to 1/32,000th of a second.
a) Time Lapse and Shutter Control can be via external computer trigger
over USB, RJ-45 or 802.11 control protocols AND can be set to X-Frames
per second to Multi-Hour intervals per frame grab.
b) Low-speed still photo and video image capture at 1, 2, 3, 4, 5, 6, 10, 15 and 20 fps
c) Industry standard integer and fractional still photo and video frame rates
of 23.976, 24, 25, 29.97, 30 fps, 50 fps, 59.97 60, fps, 72 fps, 100 fps and 120 fps
d) High speed menu-selectable 200 fps, 240 fps, 300 fps, 360 fps, 500 fps, 600 fps,
1000 fps, 2000 fps and 4000 fps (depends upon resolution or sensor crop mode).
Allows user-selectable full-frame capture that is downsampled or a crop-mode sensor capture.
e) 10-position user-selectable Neutral Density Filter set via dial on camera body.
f) High performance, full-frame-size real-time 3D-XYZ SOBEL edge-detection-based
autofocus for Video and Stills with auto-face and auto-eye detection and user-selectable
ON/OFF auto-detection/auto-recognition of vehicles, vessels, aircraft, animals and
buildings or terrain. Vector Objects Database can be upgraded via online update.
Auto-focus is better and faster than than DPAF and QPAF!
Has user selectable window-of-auto-focus and window-of-auto-recognition
that can be set ANYWHERE on-screen at any user-desired area size!
4) Shutter Speed: Standard menu-based selections and then
Increments of 10ths of a second up to 1/32,000th of a second shutter speed.
Continued below ......
  • Haha
Reactions: djkraq
HarryFilm
Jun 6, 2016
567
93
PART 2:
5) Ports and Slots:
a) One RJ-45 Gigagabit Ethernet port.
b) WiFi 801.11 a/b/g/n/ac
c) TWO USB-3.1 connectors (powered)
d) One Single-Mode Glass optical fibre connector
with SDI-over-optical interface and dual 10/40 Gigabit
Ethernet-over-Fibre interfaces.
(ST 2022-8:2019 Video over IP networking standard included)
e) One Multi-Mode optical fibre connector (for 24/32 channel 192 KHz/24-bits audio I/O)
(AES47 transport layer and MADI/AES10 interfaces included)
f) Bluetooth 4.2 for audio monitoring, wireless camera control signaling,
metadata import/export/streaming and custom applications.
g) Two HDR Displayport 2.0 ports with MST (Multi-Stream Transport for multiple displays)
and CLEAN output (comes with active HDMI converter to Y-splitter cables for legacy HDMI output).
h) Allows external multi-camera control and syncing (up to 255 cameras) via
software triggers from wired or wireless connections, real-time or time-delayed
recording and streaming to external devices and multiple internet connections
(clean signals and/or with burned-in overlays) is supported for global media distribution!
i) One ISO 518:2006 Hotshoe adapter for flashes and other lights/strobes.
j) Optional Clip-On COMBINED 4G/5G Cellular modem with built-in
Iridium Satellite Data modem + Antenna that connects to camera
via USB-3.1 connector for live-stream of video/audio/metadata
over long-range globally-capable wireless connection.
k) One NFC radio (ETSI/SCP standards AND SO/IEC 21481 / ECMA-352)
for secure smartcard and customized smartpay applications.
(camera can remain locked out until smartcard/NFC and/or
Username/Password login completes camera authorization)
l) Multiple user-assignable on-camera-body buttons and dials
used for common camera settings and menu item selections.
Functions can be set via imported XML-based button/dial
settings and assignment file.
6) Metadata Capture and Export:
a) Camera has Built-In High precision GPS and 3D-XYZ MEMS Orientation unit
that records current GPS coordinates (Decimal Degrees Latitude, Longitude and
Elevation in Meters), distance to subject in user-selectable mm/cm/meters,
current 3D-XYZ camera rotation in decimal degrees (xxxxx.xxxxx degrees)
and current local camera vibration and movement/jitter amounts and rates
on all 3D-XYZ axes in decimal millimeters or centimeters per second
(xxxxx.xxxxx mm/cm) for EVERY single frame!
b) Single Frame Grabs during video capture can be taken and exported to
JPEG, PNG, HEIF, BMP, TIFF and other file formats for use in production notes,
continuity, marketing use, and within edit decision lists. Frame Grabs can be
auto-saved and/or exported LIVE via the communications ports at the start
and end of each video shot AND at pre-defined menu intervals of between
every 5 Frames up to 60 seconds interval or set via menu to other
user-specified intervals.
c) All Metadata is saved for EVERY SINGLE FRAME to a separate and exportable
metadata track AND can also be permanently burned into a proxy video track
(at user-selectable output resolution and placements) that is separate from
the main recorded video track. Metadata tracks can be live-streamed out to
external connections via wireless or hardwired connection or saved into
XML-based spreadsheet-like tables for import into external databases
and spreadsheet applications.
e) All Video , Audio and Metadata Tracks can be LABELLED with name and
description text via imported XML file on a daily-basis or on a scene-by-scene
or shot-by-shot basis.
f) There is on-screen and viewfinder SMPTE timecode, elapsed time,
segment/scene time and current scene-elapsed-time, shot-elapsed-time
plus video frame and audio sample numbers, XML-based realtime incoming
data sample numbers and XML tag values, current local clock time and
calendar date plus extra user-specified UTC/GMT-based clock time
and calendar dates.
g) Has Vector-based and bitmap digital map overlays with tagged and highlighted
moving objects, persons, aircraft, vehicles and vessels. Can be overlaid on top of video
at user-selectable size, placement and transparency levels. This is designed for
engineering and VFX personnel that require the logging of complex GPS location
and MEMS-based 3D-XYZ camera position and rotation/orientation data.
h) Exports and uploads are via multiple Fibre-optic, USB-3.1,
gigabit Ethernet RJ-45 and wireless ports.
i) User-specific camera preferences, capture settings and button assignment
settings are importable via smart-card or via wired/wireless communications
ports and can be changed on-the-fly at any time.
j) ALL Photos and video files can be always encrypted and digitally signed
automatically on-camera (user-selectable ON/OFF encryption) using high-end
encryption algorithms for maximum security with variable usernames and password
combinations AND/OR via localized touch from a secure NFC smartcard!
(touch smartcard to live view screen to activate card-specific and
user-specific encryption usernames/passcodes and any stored
user-specific camera settings)
7) On-camera Monitoring:
a) Full-Swivel, Live-view screen that is large 5 inch (diagonal) DCI 4k OLED
with multi-aspect ratio grid overlays allowing 16-bits per RGB channel (48-bit colour)
at 120 fps realtime no-lag critical focus monitoring with NO blackout (screen allows
180-degree rotation for vlogging purposes and high angle overhead or low angle
near-ground video monitoring) and the viewfinder itself is fully electronic using
a DCI 4K micro-LED screen at 120 fps with no lag or blackout for up-close
perfectly sharp critical focus viewing.
b) Large extendable removable Eye-cup for viewfinder (has wide-range diopter)
with extra cushioning on removable and washable plush cloth covering.
c) Live view screen and viewfinder has built-in Zebra stripes
(for peak facial luminance and peak white levels at user-selectable
75%, 80% and 100% peaks), RGB and luminance parade histograms,
colour vectorscope plus overlaid vector-based or satellite digital maps
showing position of talent and tagged objects and overlaid user-defined
XML tag-based live data (imported into camera or live streamed from
external websites) are separately user-selectable for the viewfinder
and the live-view screen.
8) Audio Capabilities:
a) Multi-channel audio (up to 24 input channels at up to 192 KHz
at 24 bits per PCM sample or user-selectable compressed format audio stream)
b) User-selectable on-screen VU meters and waveform display
(on live-view screen and/or viewfinder screen)
c) Microphone or Line-level Input is Multi-Channel from External Mixer
or other external sources via USB-3.1 or via balanced XLR mic/line input
to mixer and then into camera over multimode-fibre optic connector cable
(up to 24 channels of 192 Khz sample rate at 24 bits per sample).
d) IFB (Internal/Interruptible Foldback) signals and multi-channel proxy audio
can also be saved to separate internal camera tracks via RJ-45, 801.11 WiFi or Bluetooth.
9) Onboard Storage and Data Cards:
a) File Storage is on-board via removable and hot-swappable SSD drives
(TWO 4 TB SSD drives come with Camera) store the main high resolution
video + audio + metadata. (DCI 8K video and 8092 x 6144 pixel Still images
at FULL RAW or Intraframe/Interframe compressed)
b)Two CF-express card slots for proxy video + audio + metadata files output to the CFe cards.
Usually stores 4k or 2k proxy video or half-resolution still photos used
for immediate online distribution or contact-sheet editorial review purposes.
10) Batteries and Charging:
a) Very large-capacity Li-Ion batteries allow for 6+ hours of continuous 8K stills
and video use at multiple frame rates, frame sizes, audio sample rates and
sample sizes for simultaneous multi-file/multi-stream local storage and
stream-out/external recording (via Clean Output and/or with Burned-in Data Overlays!)
b) Camera batteries can be hot-swapped without losing signal (i.e. camera has
temporary capacitor-based power buffer) AND can be directly charged via
USB port, via the on-board 12 volt to 24 Volt DC charging adapter or the
batteries can be removed for charging via the supplied multi-battery
charger unit! Camera can be used while charging and if no batteries
are available can be run directly off the charging adapter without
batteries being inserted.
11) Price: ALL of the above for a mere $8888 US!
(Lenses and Lens Prices will be announced later!)
THAT WILL DEFINITELY cause a giant ruckus in the world of stills
photography and commercial video and Hollywood cinema production!
This is DESIGNED to Compete and EXCEED the capabilities of
Arri Alexa-65, Red Monstro, Canon C700, Sony Venice, Sony A92,
Sony A7r4, Canon 1Dx2/3, Fuji GFX-100, Leica, HasselBlad,
Phase-One and other pro and consumer camera manufacturers!
And THAT IS ONLY A TASTE of what is to come very soon now,
as TWO large image sensor (2/3rds inch and APS-C) IP-68 ruggedized
super-smartphones and TWO large sensor (2/3rds inch and APS-C)
IP-68 rugged super-tablets are being introduced at the same time!
ALL COMING SOON to an Online store and Bricks'n'Mortar store near you!
The Ball is in YOUR COURT NOW CANON AND OTHERS !!!!
  • Haha
Reactions: djkraq
HarryFilm
Jun 6, 2016
567
93
I'm not holding my breath. Harry, you have yet to deliver on ANYTHING you've promised.
I don't sell the stuff ... I just make the CODECs for it!
I am 2/300 right on my predictions so that is a 0.6% prediction correctness rate!
That's Not Totally Bad!
Plus, not to be too persnickety about it, BUT i'ts NOT my job to deliver a camera to you ... HOWEVER... It IS MY JOB to make sure certain advanced feature sets get introduced into the pipeline to make sure PROFESSIONAL PRODUCTION PERSONNEL and high-level end-users have their working lives made a tad bit easier when it comes to providing specialty imaging solutions for Commercial and Cinema Production, Pro-Sports/Action Stills Photography, VFX and Scientific Imaging and Visualization.
THESE new imaging solutions noted at the top of this forum WILL provide those advanced imaging solutions!
What WILL DEFINITELY SHOCK YOU though ..... is WHO will be introducing such technology!
This one WILL BE A DOOOOOOOZY!
We DO live in Interesting Times !!!!!!!!!!!!!
Now it's off to the Aerodrome to get another lesson in the Bell 429 .... !!!
SecureGSM
2 x 5D IV
Feb 26, 2017
1,945
867
Not Jeff Bezos from DPReview?
Nope. it is in the news all over the world. Elon Musk is on the mission to fix Australia internet and to revolutionise photography by introducing a Medium Format Sensor 8K/50.3 Megapixel Combined Stills/Video Global Shutter Mirrorless Camera. as per Harry's write up above.
Musk has previously demonstrated the technology does work by using one of the satellites to send a tweet last year. :
Kit.
Apr 25, 2011
1,742
1,084
Actually, it's a nice combo to bring with yourself on a safari. Could produce the most famous last photos.
  • Haha
Reactions: SecureGSM
Del Paso
M3 Singlestroke
Aug 9, 2018
796
824
I know this mysterious 6 x 6 MF camera.
In fact, I've already tested it, he he he.
It's named the Brownie, made by a company whose name I'm not yet allowed to divulgate.
  • Haha
Reactions: CanonFanBoy
HarryFilm
Jun 6, 2016
567
93
Nooooooooo..... Harry, you mixed it up again. It was Elon Musk from Space-X. Don’t you recall?
No! Seriously! It actually IS APPLE !!!
Really! They have their own CMOS imaging chips and New iPhones/iPads with 2/3rds inch and APS-C sensors!
and a really fancy large MF 8K Stills/Video camera system !!!
PLUS there's both a polymer 3D printer coming out AND a 3D metal deposition/laser sintering printer coming out for the new Mac Pros! It's very easy to connect, use and maintain -- It's a quite a step beyond what is offered by others out there! The new multi-colour plastic extrusion media comes in pre-packaged bundles that are hot-swappable and relatively cheap to buy and come in 6-colours for now! (more colours coming soon!)
The 3D-XYZ laser sintering system is 1/20th the price of the major vendors and again, the metal Aluminum Powders, Titanium Powders, Stainless Steel powders (in various strength and corrosion resistance grades for all powders) are all pre-packaged and bought online from Apple store.
Both 3D printing systems have a 300 x 300 x 300 mm objects version, a 500 by 500 by 500 mm objects version, a 750 x 750 x 750 mm objects version and a 1500 by 1500 by 1500 mm objects version so you can choose which cubic size of object you wish to manufacture at the price level of 3D printer you can afford to buy! Apple is going head to head with EVERY 3D printing company out there. This will result in a whole new income stream for 3D printers and metal powders and polymer media!
To power all of this, they bought a small CAD/CAM/FEA software maker and remade its software for their own 3D printing products AND they made it a LOT easier to use and understand but with similar capabilities to CATIA! It does run ONLY on Mac Pros and Macbook Pros though! Think of it as a Final-Cut Pro for 3D Printing!
Apple is now going after the engineering and mechanical design people the way they went after desktop publishing in the 1980's. They're making an ENTIRELY NEW INDUSTRY for the localized manufacturing of high-quality plastic and metal parts AND a 3rd party 3D-design market within the Apple Store allowing you to sell your designs and buy/licence other people's designs !!! You've heard of DTP (Desktop Publishing) ... NOW... you get DDM (Desktop Design and Manufacturing) -- All from APPLE !!!!
SO YEAH! I think this is a bit of a REALLY BIG DEAL !!!
They made the DCI 8K/50.3 Megapixel MF camera because it is ALSO a 3D scanner for the 3D printing systems as are the new large-sensor tablets/smartphones!
Guess what! ... IT'S ALL REAL !!!
  • Haha
Reactions: djkraq and cayenne
SecureGSM
2 x 5D IV
Feb 26, 2017
1,945
867
Hang on a second....
++++ Really! They have their own CMOS imaging chips and New iPhones/iPads with 2/3rds inch and APS-C sensors!
You have previously reported that Full Frame sensors are coming to mobile phones Very soon.
Now it’s only APS-C sized instead. What Happened there? talk to Apple. We need FF sensor in there phones as soon possible.
Let us know.
  • Haha
Reactions: djkraq
HarryFilm
Jun 6, 2016
567
93
Let us know.
I am assuming Canon and Sony ARE working on FF sensors for smartphones (at 6.3 inch screen sizes to make it work) but APPLE has focused on 2/3rds Inch and APS-C sensor super-smartphones and tablets.
It's the OTHER camera systems designed for DDM (Desktop Design and Manufacturing) that is the kicker here, as it is part of a 3D scanning system AND high end digital 3D photography push from Apple which is WHY the IR and RF distance channel is in the RGBA/YCbCrA pixel layout during recording of video and stills on the new MF camera!
While great for high end enthusiast still photography and cinema production, this MF camera is really designed for the engineering and mechanical design side of things in order to get real-world 3D objects into the digital realm for use with the new APPLE branded 3D polymer printers and 3D laser sintering printers. (p.s. they were designed ENTIRELY in-house by Apple! -- The CAD/CAM/FEA software was bought from a 3rd party and upgraded/modded by Apple!)
This will be like the Canon, Epson and HP inkjet printers of old where they made money on selling bucket loads of expensive INK and sold the printer hardware for cheap! Apple will make the REAL MONEY on the Metal Powders and multi-colour polymer media used in 3D printing, and make good money off the Apple 3D Design Store while selling high-end, easy-to-use 3D printers for MUCH MUCH CHEAPER than the competition!
There are FAAAR MORE one-man band engineers, small-to-medium manufacturing and industrial companies and small-to-big design firms who will buy premium-quality Apple 3D printing systems than there are professional and enthusiast photographers who need cameras. Apple is looking at a serious income stream within ONE YEAR of introduction. This gear is NOT CHEAP for consumers but is DEFINITELY INEXPENSIVE for design and manufacturing professionals!
YES! This is VERY VERY REAL !!!
CanonFanBoy
Really O.K. Boomer
Jan 28, 2015
4,847
2,821
Irving, Texas
Let us know.
I've always wished my smartphone could be even bigger. ;)
