Firmware: Canon confirms January firmware release for RF 70-200mm f/2.8L IS USM fix
Canon EOS 40D
10,830
3,196
A couple of weeks ago it was reported that Canon would be releasing a firmware update to fix an autofocus issue with the brand new Canon RF 70-200mm f/2.8L IS USM when shooting at or near its minimum focusing distance.
Canon has now confirmed that the update/fix will come in January 2020.
It has been confirmed that when using the RF70-200mm F2.8 L IS USM to perform AF shooting to capture a subject at close-range with the focus distance approximately set to the Tele-end (200mm), the image may become slightly front-focused.
New firmware with improved focus accuracy is scheduled for release in the beginning of January 2020, and once the preparations are completed, we will post the information on our website.
Note: New firmware being released at this time is for lenses equipped with firmware version 1.0.5 or earlier. The lens firmware version can be checked in the camera’s menu.
Note: New firmware being released at this time is for lenses equipped with firmware version 1.0.5 or...
Continue reading...
YuengLinger
Print the ones you love.
3,782
2,310
USA
Even Canon lets a mistake loose in the wild once in a while. Makes me feel better about one of my biggest, dumbest blunders. Happened just last week. About 25% of an Xmas program, shot on the EOS R (which was a companion, fortunately, to a 5DIV), inadvertently low-level formatted. DOH!!!
(In the meantime, I've set my cameras to NOT low-level format SD cards by default, and taken other idiot-proofing steps).
Sigh... Even Canon screws up now and then. After all, we are only human.
Looking forward to the firmware update AND some reviews confirming the problem has been solved! Intensely curious about this lens.
jdavidse
R5
142
179
I was curious if people were actually shooting at a few millimeters less than MFD and experiencing the problem, rather than the actual MFD.
If you were shooting a few mm less than MFD, the image would be back focused, not front focused. The camera would also not be confirming focus lock
jdavidse
R5
142
179
Question Do only certain EOS camera's allow the Lens Firmware upgrade? or does canon have a USB doc like Sigma?
These are RF lenses and the only 2 bodies compatible with the lenses allow you to upgrade the firmware via SD card- exactly like the process to upgrade the body firmware
