Do you ever put a small amount of grease on your filter threads? If so, what do you use? Graphite? Teflon? Other?
I don't use any kind of lubricant.Hillsilly said:Do you ever put a small amount of grease on your filter threads? If so, what do you use? Graphite? Teflon? Other?
Maximilian said:I don't use any kind of lubricant.Hillsilly said:Do you ever put a small amount of grease on your filter threads? If so, what do you use? Graphite? Teflon? Other?
B+W says the following:
"... in no instance should you use oil or silicone spray, as these lubricants can find their way between the elements of the lens and can thus cause considerable damage to the imaging performance of the optics."
See here, last FAQ (How do I release B+W filters that are stuck in place?):
http://www.schneiderkreuznach.com/en/photo-imaging/product-field/b-w-fotofilter/products/faq/
I see the same with, with graphite, teflon, etc. But I haven't found anything about that.
Of course you can think different of that .wyldeguy said:They mentioned oil or silicone spray not to be used to remove the filter. The op is asking if people put some on before attaching. I heard it was recommended for ease of removing later. I believe a Teflon or graphite would be best but I have not used any myself. I was thinking of starting to do it. Just a little dab on the filters thread itself should be enough.
Very good point!AcutancePhotography said:I think it would be more beneficial if the threads on the camera and filter were carefully cleaned before putting on the filter. If you are using a good quality filter, I think that grit in the threads is more likely to cause sticking.
I would not put any substance in the threads. I want to remove all the substances in the threads.
[email protected] said:You'll think this is nuts until you try it.
