How many shots per battery charge of the EOS RP will you get?
How many shots per battery charge of the RP will you get?
  • 50-100
  • 101-200
  • 201-300
  • 301-500
  • 501-750
  • 751-1000
  • >1000
Results are only viewable after voting.
My R gets around 1000 or more, I've turned review off, not for battery life, but to speed up ability to take subsequent shots. I've never actually run the battery down, I had about 800 shots with 25% battery left, so I changed batteries to make sure it did not die at a critical moment.
I do think that the way a camera is used greatly affects battery life. My shots happened over about 3 hours or less, I had two cameras, my 5D MK IV with 70-200 and the R with 24-70 and the next night, I switched lenses around just to compare. I could not tell a difference in battery life, but I'd expect a telephoto lens to shorten the battery life. I have a USB Battery and a converter (Case Relay) which has enough juice to outlast several LP-E6 Batteries. I actually used it after the 800 shots just to verify that it worked reliably with the R. I snapped a shot of it before using it. I also had a LP-E17 adapter that went with my SL-2, I gave it to my granddaughter.
I also have a cheap 50 watt USB C Charger (~ $25) which charges my R just fine.
Maximilian
5,711
8,642
Hi AlanF!
Sorry, but why making a poll now out of a pure guessing game as no one has the EOS RP yet?
Only thing one could do is looking at the CIPA numbers, using some math maybe comming from the EOS R and say with normal use you'll make 1x0% of the CIPA numbers.
My approach would be:
Wait until release and then ask again.
My vote would be (missing option): "No clue!"
Desperately seeking birds
12,441
22,877
Hi AlanF!
Come on Maximilian, have some fun!
