at any given bitrate, IPB can always deliver better image quality (it does the same, with less restrictions, so it has to throw away less info); but once the bitrate is high enough, the difference is very small, and IPB becomes too complex to encode and decode, whereas intra remains useable
"the intra advantage" is that it is less complex, and given enough bitrate it doesn't need to throw away a lot of information
in any case, in relation to the 1DX, there is a lot of conflicting information regarding codec and bitrate
mainly, we have two different bits of information regarding codec and bitrate:
* first, dpreview said: “a 16Gb card will hold around 6 minutes of footage†which means 350Mbps
http://www.dpreview.com/articles/5149972341/canon-eos-1d-x-overview
* now, canon professional network says: “When filming with ALL-I, file sizes will be around three times larger than with IPBâ€
http://wideopencamera.com/just-the-cut/canon-1d-x-what-the-compression/
only one way to make those match: in the dpreview thing 16Gb actually means gigabits, IPB is 17Mbps, and all-I is 50Mbps
but who uses gigabits to talk about SD card capacity? and who is still using 2GB cards?
if this is right, it means 8 bit, and probably 4:2:0 too
let’s wait and see, but it could be very disappointing
