First of all... I know it's bad... but I'm just trying to knock down one pin at a time to get this thing right.
2nd - Technique...
Monopod mounted (which I know isn't as secure as a tripod, but it was in a walkway... so this is the best option without potentially killing people... But the monopod was reasonably stable... used a wireless shutter release... and hit the shutter here and there in order to get a progression of still movement. Then I placed the different images into photoshop using muliple layers... deleted the portion that didn't have the player, and then left the section with the player in the respective layers. Then flattened the image. The image settings for the series was manual, iso 3200, f/6.3 (and I realize that is high and i didn't fix the grain, but that is the least of my concerns), and 1/200 of a second.
So it is pretty obvious that when there are no players on the ice, the camera meters the image differently. I dont' think the variance in exposure is related to light/white balance flicker. So... to correct this... instead of using (.) I should probably opt for ( )... or I can just brighten it in lightroom and then export it to photoshop (elements 12) so it matches the others or at least comes close.
So... if I do this outside under clouds... taking a shot before... then selecting out another image to lay over the background layer... will I experience this same sort of variance? I feel as though i will. So if it is metering... how do I get that to stick. With the lock toggle on the back of the 5d mkiii work... or is that just wishful thinking.
Sorry for sounding so naive... I usually try to hide my naivate' and simply edit single images... but this combing of images is killing me slowly.
2nd - Technique...
