Lens cleaning solution
Jan 16, 2014
73
I have been using one of these
https://www.amazon.in/s/ref=nb_sb_ss_fb_1_7?url=search-alias%3Daps&field-keywords=lens+cleaning+kit&sprefix=lens+cl%2Cindustrial%2C439&crid=OLJGGDK9IS31
the solution is almost used up, so I need a new one. this time I want to buy only the solution not the brush, cloth, air blower etc. as those are still in good condition and very much usable.
Can you please mention what is the name of solution? Is it Isopropyl alcohol(IPA)?
ahsanford
Particular Member
8,620
1,651
If you mean the front/back glass elements of the lens, I've been using this with a microfiber cloth for years:
https://www.bhphotovideo.com/c/product/64495-REG/ROR_RO212D_Residual_Oil_Remover.html
But if you are referring to cleaning the outer housing of the lens (i.e. the barrel, sides, switches, etc.), I have no idea. I presume a damp cloth would do.
- A
ahsanford
Particular Member
8,620
1,651
neuroanatomist said:
I use Zeiss lens cleaner, which is ~5% isopropyl alcohol in distilled water.
The ROR solution that ahsanford mentions has other ingredients, as well:
Ammonia 0.775%
Sodium Chloride 0.830%
Isopropyl Alcohol 4.266%
Liquid Soap 9.011%
Distilled Water 85.118%
Any concerns there, Neuro? Seems to have worked fine for me and no residue has built up, but I'd have no idea if that was eating a coating or anything.
Though in fairness, most of my lenses only see open air and require cleaning for 1% of their lifetime, I'd guess. I'm overwhelmingly using ROR on either the CPL or UV filter instead.
- A
1,920
39
Of the ingredients in the ROR solution, I'm concerned with sodium chloride and ammonia. I know it contributes to corrosion of metals. Ammonia may do so, too.
I like a tiny bit of surfactant, detergent soap, as it helps with binding with oils.
Don't use isopropyl alcohol one gets from department stores especially formulated for beauty products, as some contains a small amount of oils to "protect" the skin.
-r
31,183
13,041
Purisol liquid, and have recently discovered Pearl Vision wipes. At $7 for a box of 70, they are a type of foam "fabric" made especially for coated lenses.
Zeiss also has pre-moistened lens wipes:
https://www.amazon.com/dp/B00MVR5OD8/
They’re great as you can just put a few into your camera bag. I also have pre-moistened DEET wipes for use in the summer. I do try not to confuse the two when I use them.
