I was at a wedding with an old 70D and a new 35mm F/1.4L II and noticed when the lights dimmed for dancing I had a real tough time locking focus for stills (I had a Speedlite so the actual shots were properly lit).
As I process my results I'm left wondering how modern cameras would handle that situation.
My first thought was to assume that a full-frame body would be better equipped to focus in low-light but then I realized that would only be true if you were shooting in Live View (which I don't use). Can anyone please confirm my theory that the sensor size does not directly effect auto-focus?
My second thought was to look for specifications on various bodies to see if there was some real way to compare but all the specs seem to talk about Dual Pixel CMOS AF (which I believe also only applies to Live View?). Can anyone please confirm that DP CMOS AF is irrelevant for SLR stills since it focuses while the mirror is down and the sensor is blind?
I assume there's improvements with each generation -- some software, some hardware -- but I just wish there was some sort of standard measurement I could use to guide upgrade purchases.
I concluded that there were only two technical solutions I could rely on:
1) Faster glass since even though I wouldn't be likely to shoot at 1.2 the AF works with the lens wide-open.
2) A low-intensity ring-light on the lens for AF assist (blasted out by the speedlight)
Have I missed anything?
