Mirror lock or live view for stills ?
May 20, 2013
368
7
I have been using the mirror lockup feature to reduce vibrations when shooting landscapes with my Canon 5D Mk IV, it has been suggested to me that triggering the cameras shutter when in live view mode would be a better option for stills. It would mean one less shutter press (via remote cord) per image, which would be an advantage when capturing landscapes with moving elements like waves. Are there any disadvantages in using this method other than obviously not being able to see through the viewfinder and increased battery usage ?
4,549
448
57
Hi bitm.
I don’t actually see not being able to look through the viewfinder vs live view when doing landscapes as a disadvantage, to me it allows for the camera to be positioned at higher or lower vantage points that would make viewfinder use uncomfortable at the very least! As for battery use, I don’t know how live view would affect a day of landscape shooting, I can’t manage a day of that! :)
As far as moving elements and one less press of the shutter button, unless you are trying to catch a breaking wave or similar, timing of a landscape seems pretty flexible!
Sporgon
4,720
1,540
Yorkshire, England
Personal preference, but in LV you are probably using electronic first curtain, so when you take the shot there is only movement from the shutter closing, there is no physical opening. So theoretically that is better from the point of view of reducing vibrations to the very minimum.
Live view is definitely better if you would be using mirror lockup anyway. It means you'll get to see the exact framing and exposure on top of having 0 vibration. The only reason to use mirror lockup but not live view is if you have your back to the sun and there's too much glare on the screen to see it, or if you were shooting action where the screen might lag a little.... but there aren't going to be many times people shooting action would care about mirror lockup and obviously landscapes don't move enough for the lag to matter!
4,549
448
57
Hi Lexa.
Unless there has been communication between you external of this thread I think you are reading too much in to Sporgon’s replies.
Also you should be aware that threads here regularly veer off topic and back on again just as a normal face to face chat over a beer will, if this worries you I would submit that Internet fora are not for you!
lexaclarke said:
Your definition of "being nice" is extremely close to my definition of "being a creepy stalker weirdo harassing and trying to start fights and drag threads off-topic" so how about we agree to disagree and that whatever your intentions are, you need to reevaluate.
512
212
Does the 5DIV have the variable delay shutter that the 5Ds has? For my handheld landscape photos I have this set to a half second delay after the mirror goes. The delay is not a problem for non-action shots and apparently significantly reduces mirror shock (I have yet to test this).
On a tripod I invariably use mirror lockup with 2 second self-timer.
Sporgon
4,720
1,540
Yorkshire, England
No 5DIV doesn't have this. Just 5Ds / sr.
Sadly not. IIRC the 5D mark IV has the shortest shutter delay of any current Canon and they probably didn't want to put in anything which could complicate that. I hope to see the feature put into all bodies from now on. Hopefully Canon will listen if we make enough noise about it.
Valvebounce said:
Hi Lexa.
This is literally like the third time he's done this in the space of about one week alone.
31,186
13,043
Someone with >3500 posts (and an average of 1.2 posts per hour online) has replied to you in three threads in a week, and that's harassment?
With respect, get a grip. As they say, if you can't take the heat*, stay out of the kitchen.
*In this case, 'heat' is like a couple of degrees north of room temperature.
RGF
Jul 13, 2012
2,820
39
Valvebounce said:
Hi Lexa.
What is IIRC?
RGF
Jul 13, 2012
2,820
39
I tend to compose landscapes, at least initially using the OV. I will go to LV for the final shot. Even then I will often use a 2 second delay unless I am concerned about the breeze blowing the grass (or something like that). One nice I have found is the bracketing, I can set the 2 second delay and get all my shots fired off at once.
On my 5DMkIV, I have a dedicated custom setup (C2 in my case) for landscapes. It's set to mirror lockup and 2 second delay, however normally I use LV + exposure simulation for landscapes, also with a 2 second delay (10 seconds if windy). LV + exposure simulation work fine with filters, sometimes I can even focus with a 10-stop ND. OV doesn't work well with ND filters obviously.
In order to check the camera is stable on a tripod, I use magnification in LV. Tiniest jitter will be visible at max magnification.
In some cases I use WiFi + remote shooting, it eliminates any man-made shaking completely.
Also it's easier to preview the scene and composition in LV, you can remove all information and have a clear preview in LV, you can even set the aspect ratio to say 1:1 and preview your composition in 1:1 (if you're having 1:1 aspect in mind for the scene).
So OV doesn't work for me in landscapes at all, however I use OV whenever the camera is *not* on a tripod.
Quoting myself... A few days ago I was shooting from a riverbank at a small backwater lagoon and there was a very tiny island maybe 1 metre from the shore, basically just a hillock in the water. I jumped on it and there was a nice view, so I set the camera up on a tripod. I took a couple of shots with ~5 sec exposure and they were all blurry. I couldn't understand why until I set max magnification in Live View. Apparently, the ground was very wobbly and unstable, so the camera would move as I was breathing! I only got a sharp shot after I set it to wifi-remote shooting and jumped back to the shore leaving the camera alone on the hillock.
4,549
448
57
Hi Quark.
Yes, I t can be quite alarming how ‘flexible’ a firm surface can be.
I do some voluntary work at a Hide which overlooks a peat mead, when we were doing some ditch clearing with a mini excavator you could get ‘seasick’ from the waves passing underfoot every time the excavator made a movement even when stood 50 feet away, most unnerving until you get used to it!
RGF
Jul 13, 2012
2,820
39
Valvebounce said:
Hi RGF.
IIRC If I Recall Correctly.
I do wish people using these abbreviations would take a second to realise that they are ‘talking’ to people from many nations, not all of which speak English as a native language.
RGF said:
What is IIRC?
Sorry I thought it was a photo term. If I knew it was computer slang, I would have looked it up.
4,549
448
57
Hi RGF.
And therein lies the problem, if you had known it was computer slang you probably wouldn’t have needed to look it up, you would have already known what it meant. ;D
