Mobile Redirects Currently Plaguing the Mobile Web
EOS 1D MK II
7,595
313
HTML:
There is an internet wide annoyance currently affecting popular web sites. What used to only be a problem with clickbait junk sites has now hit the mainstream.</p>
<p>It’s not just Canon Rumors, this is an internet wide issue with sites like Yahoo, CNN and the New York Times suffering the same issues. We serve ads through Google and other top networks, and they are working hard to find a fix.</p>
<p>For example, last evening I was browsing Autoblog and I was hit by a redirect while using Chrome/Android. My system administrator has had the redirects pop up on Yahoo! It seems to happen to sites the user visits a lot, I’m on Autoblog 4-5 times a day and this is the only place I’ve had a redirect personally hit me. If I see a redirect, I dump my cache and restart my device.</p>
<p>Just because it only happens on Canon Rumors for you, doesn’t change the fact that this is a randomized issue affecting most popular web sites on the internet. As far as I know, this only affects mobile operating systems. I haven’t heard anything from desktop users.</p>
<p><strong>What can you do about it?</strong></p>
<ul>
<li>Try viewing our site directly and not through Facebook or Twitter links.</li>
<li>Others have found clearing their cache and browsing history has eliminated or reduced the occurrences.</li>
<li>Try the latest version of Chrome to see if it reduces or eliminates it from happening.</li>
<li>You could turn off JavaScript and that should eliminate the issue. I’m not sure what affect that will have on browsing. (thanks docsmith)</li>
</ul>
<p><strong>Here is a story explaining this annoyance.</strong></p>
<ul>
<li><a href="https://www.wired.com/story/pop-up-mobile-ads-surge-as-sites-scramble-to-stop-them/" target="_blank" rel="noopener" data-saferedirecturl="https://www.google.com/url?hl=en&q=https://www.wired.com/story/pop-up-mobile-ads-surge-as-sites-scramble-to-stop-them/&source=gmail&ust=1518886633849000&usg=AFQjCNEmabn53ygwtSq4_rNebIN9PilcNg">https://www.wired.com/story/<wbr />pop-up-mobile-ads-surge-as-<wbr />sites-scramble-to-stop-them/</a></li>
</ul>
<p>Every ad network that I know of is working on how to prevent this new and effective annoyance.</p>
<p>Thanks for your understanding.</p>
kaihp
I'm not new here
Mar 19, 2012
847
4
Another reason why adblockers seem like the best solution these days - way too much uncontrolled crap through the AdSense & friends :-\
And yes, websites like CR needs to cover the costs and hopefully make a living for CRguy. We're between a rock and a hard place.
I forget: did we do the "premium" membership where you can go ad-less?
EOS 1D MK II
7,595
313
The AdBlockers aren't preventing this, as they're based mostly on blacklists and this stuff is changing so quickly. I have hopes for the new Chrome and what Google is doing with killing annoying ads.
We'll be doing a premium service in the coming months. I don't like doing everything all at once, so the forum first and then the web site.
docsmith
Sep 17, 2010
849
200
I haven't had an issue since turning off javascript. On my iPhone, go to Settings, then Safari, scroll all the way to the bottom to "Advanced" and then turn javascript off.
EOS 1D MK II
7,595
313
Absolutely that will work, I imagine all the bad code is JavaScript based.
Are you having any other issues without JavaScript turned on?
LDS
Sep 14, 2012
1,531
125
"and they are working hard to find a fix"
No, they aren't because it will hit profits. They could vet advertiser and their ads, they could ban JavaScript. But their model is accept everything and then put a Band-Aid on bigger issues, when they put them in bad light.
Photographers are expected to work abiding to ethical standards, adsmen are not.
IglooEater
Nov 15, 2014
903
I think I’ve had this a few times too. Funny thing is I don’t even have a Facebook or Twitter.
15,365
621
Actually, they are working hard to fix it. They lose money because of this. Yes, they could ban javascript, but the real issue is that the ad process has been automated to save money, no one checks or vets them, anyone can remotely signup and submit a ad as long as they pay.
So far, we don't even know where they are coming from. I've never seen one, but that is likely because I seldom use my iphone to browse web sites.
9VIII
Feb 8, 2013
1,843
After using iOS for a little over four years I've found that running Safari with Javascript turned off is almost as good as running Ublock Origin on PC.
99.9999999999% of websites assume everyone always has Javascript turned on, and their ads don't work if you turn it off. It's an amazingly simple thing to get around.
Yes, about 20% of the web doesn't work without Javascript, I probably have to go and flip it back on once a week in order to buy something, but understand that browsing the web with Javascript turned on is like running around in public with no pants.
On PC I also use Noscript to block absolutely everything by default, and then I only start allowing scripts if I really want to see some of the script based content on a given site.
Also it helps to set your browser to clear everything every time you close it (and then make sure to close your browser every time you're done using it).
docsmith
Sep 17, 2010
849
200
Very similar to what 9VIII describes. I usually do not even notice that I have it off. It has probably been 3-4 times that I have to turn it back on. Usually for videos or gifs.
BeenThere
Sep 4, 2012
835
162
Turning off JavaScript on my iPad sure cleaned things up (in Safari menu). I’m sure there will be times when it has to be enabled, but so far i’m liking it.
magarity
Feb 14, 2017
154
60
Computers and the internet would be so much cooler if some people weren't phishing, spamming, scamming jerks.
JMZawodny
1Dx2, 7D2 and lots of wonderful glass!
Sep 19, 2014
380
Virginia
Joe.Zawodny.com
This is why I use a combination of NoScript, ad blockers, and white lists on my browsers. NoScript can be a pain on some websites that rely heavily on external scripts (sometimes layers of scripts that then call scripts from other sites, ...), but it is pretty rare for content to be available from online source these days. You can usually find a different way to get the info you want.
While these tools help, nothing is foolproof.
IglooEater
Nov 15, 2014
903
+1. Though I wouldn’t limit that statement to computers and internet.
EOS 1D MK II
7,595
313
The largest ad network in the world has updated their browser to block what is deemed to be annoying and intrusive ads. These sorts of malicious ads are bad for business.
kaihp
I'm not new here
Mar 19, 2012
847
4
Let's see: I got AdBlock-Plus, NoScript, Ghostery, Self-Destructing Cookies, and Tampermonkey running in Firefox. I rarely (if ever) see an add that isn't integrated directly into the HTML. (It does make for a more cumbersome browsing experience though).
I understand the priorities and appreciate the "premium" version coming.
Thanks.
LDS
Sep 14, 2012
1,531
125
Are you sure? It's no surprise you've seen a surge in these ads, even on highly visible sites that should use reputable suppliers, exactly when Google is releasing a browser to block them, and sites hurry to recommend Chrome - not ads blockers (which are far more effective than those articles say) - to block them. A very strange coincidence.
Google, together Facebook, already dominates the online ads business and has three aims: 1) Avoid more people to start using ad blockers that block its ads too 2) Broaden Chrome dominance because that's a gateway to the full users activities, data that can also used to sell more ads, something Facebook misses 3) Be in the position to block competitors ad networks at its will (a true conflict of interests).
We're speaking of the company that knowingly helped to sell drugs unlawfully, and settled with the DOJ not long ago (https://www.justice.gov/opa/pr/google-forfeits-500-million-generated-online-ads-prescription-drug-sales-canadian-online), to avoid a full investigation.
I'm sure it will soon be under the radar of EU antitrust.
kaihp
I'm not new here
Mar 19, 2012
847
4
Vestager (the competition commisioner) will probably have a field day with this :D
