Northlight reviews the Laowa 25mm f2.8 2.5-5x Ultra Macro
HTML:
Keith over at Northlight Images just posted a <a href="http://www.northlight-images.co.uk/laowa-25mm-f2-8-macro-review">detailed review of the Laowa 25mm Ultra Macro</a> complete with some pretty fascinating sample images.</p>
<p>I’ve always found Keith’s reviews to be quite detailed and chock full of great sample images, and this one is no different.</p>
<p>Oh, and about the Laowa?</p>
<p>Keith has this to say;</p>
<blockquote><p>From an image quality point of view, there was little I could fault the lens with. It shows a slight bit of longitudinal chromatic aberration (purple/green tinges to OOF areas), but not excessive.  The 8 blade aperture gives better looking OOF highlights than the 6 bladed Canon MP-E65mm.</p>
<p>The only area that may concern some is the lack of stop down, meaning that it’s either a dark viewfinder at smaller apertures or you have to stop down manually before the shot. It’s no problem for my sorts of use.</p>
<p>The magnification setting is firm but I did notice that careless adjustment of the aperture could easily lead to a slight change in the magnification setting, and hence move the plane of focus. This was worse when the lens was pointing downwards <em>[do note though that this was a pre-production lens]</em></p>
<p>The build quality of the lens feels good and the sample I tested came in a soft neoprene bag.</p>
<p>Ultimately this is a lens you’ll want for fine detail, and it definitely delivers.</p></blockquote>
<p><a href="http://www.northlight-images.co.uk/laowa-25mm-f2-8-macro-review">Read the review here…</a></p>
Chaitanya said:
Thanks for review. It does look like a good option to MP-E 65 and its smaller and lighter.
Glad it was of interest - the lens is another in the 'bit different' category from Laowa.
If anyone is going to 'The Photography Show' in the UK this month I believe Venus Lens will be there. I'm curious to see their 24mm super long 'relay lens'.
jolyonralph
Game Boy Camera
1,423
944
London, UK
www.everyothershot.com
Antono Refa said:
The MP-E is on the long side of normal, the Laowa is on the ultra side of wide, how can one be an alternative to the other?
When you get to 5:1 magnification this makes less difference than you'd think.
Look at the comparison sample images in the review - note all the settings etc
Focal lengths (nominal ones), fields of view and aperture settings (as opposed to effective aperture) show themselves in your images in distinctly different ways in using lenses like these.
Essentially, forget a lot of what you think you know about such things for 'normal' use ;-)
yeah, right, the working distance is almost the same. In my opinion staarting at 2.5x instead of 1x is a big disadvantage.
It came in for me just luckily, i the same day got a mp-e lens which i catched at ebay for great price. Ans yes, it's not easy to use, and without the usual accessories it's useless. Without tripod, maccro flash and sstacking software it can not show what iit can do.
But wow how this old style lens (released 20 years ago) is wonderful build quality.
Good review. For someone starting out in ultra macro work, this looks like a good option. The shape of out of focus areas is one weakness of the MP-E, especially specular highlights, and this new lens certainly looks a lot better in that regard; the lack of electronic aperture control is a serious tradeoff (and the lack of 1-2.5x magnification, which may or may not be a problem depending on what one intends to shoot), but for the price it otherwise looks to be pretty excellent.
I looked at the MTF charts of this and the 65mm, and the Canon looks to be much better on paper, although I have to admit I didn't have the color key with me to indicate which lines represented which measurements. I look forward to the inevitable apples-to-apples shoot-out.
In terms of the aperture control, I don't mind the manual bit. I use a couple manually controlled aperture lenses for macro (in addition to Canon macros), and personally, I find it to be fine. The electronic swapping of apertures in the camera tends to annoy me a little because it is always turning dark at the moment focus is needed, so there is this constant pressure to be pressing the shutter button half-way to keep it on. With the aperture ring, I feel the process is more relaxed.
-tig
PS: I recently purchased the Mitakon equivalent of this lens for $169 and was quite happy with the image quality. Maybe this falls out of Dustin's realm of expertise, but I'd love to see someone take the three or four 1X-5x type lenses and put them through paces.
-tig
The problem with MTF charts is that comparing ones from different manufacturers is fraught with difficulty (essentially meaningless some might say ;-)
For myself, the comparisons that matter are the sorts of shots I've included in the review - I've lots more than the examples included, but my take-away views of the difference between the two are summed up in the ones I've used. There is a balance in writing such reviews between 'completeness' and utter tedium ;-)
As a long time MP-E 65 user, I find this lens intriguing simply because it now offers a "relatively" easy high macro solution for other systems.
I think the biggest facet that this review misses is how easy the MP-E 65 pairs with the MT-24EX in the field. The flash heads can clip right next to the lens, and there's even a special hood to prevent some light from reflecting back in. This is huge for using it in the field for things like insect photography.
I'm curious if Laowa or some other manufacturer will make an adapter for this lens. Lighting is a huge challenge at this magnification, and most insect photography must be done without a tripod.
I'd note that it is not an MP-E review (I link to one I did a while ago) - but I will note in a bit more detail the relative ease of attaching stuff
I have been talking to the manufacturer about such flash adapters...
That said neither are lenses I ever take outdoors - just not the sort of stuff I really shoot
1,861
1,099
38
Pune
Venus/Laowa sells a 60mm Macro which goes from infinity to 2x, so I think their logic behind this lens might be that 25mm will complement the 60mm Macro.
-tig
Mitakon lens only goes from 4x to 4.5x mag ratio, has only 3 aperture blades and its "narrower" at only 20mm while this Venus lens is 25mm and shoot from 2.5x to 5x mag ratio and has 8 bladed aperture.
