Patent: Refined fully articulating screen
EOS 1D MK II
7,533
289
A patent showing a refined fully articulating screen for cameras has appeared at the Japan patent office (Patent application: 2018-133632).
This patent actually looks at changing the backlight intensity of the LCD depending on how the articulating screen is positioned.
The second part of this patent application looks at how to make the hinge that operates the articulating screen smaller. The engineering required for these hinges is quite complicated.
From Japan patent application 2018-133632:
Also when the surface where an illuminance detection sensor is arranged when the display device combined with the rotatable biaxial hinge is operated differs from the surface which the display device has turned to largely, an illuminance detection sensor will be interlocked with, and the brilliance control of a display device will be controlled by a prior art. that is, a luminance change of an unsuitable display device (TFT) is made — like — problem occurs. When the illuminance sensor...
Continue reading...
Maximilian
Nov 7, 2013
2,495
286
Really interesting.
I would welcome every patent, that would reduce the size of the hinge without making it weeker.
About the "backlight intensity " : would like to see, how well that works together with the "detection sensor ".
Aug 23, 2018
3
I'm not a fan for the swing-out-to-left screen of my M50. I'd rather have the new patent that swings out up. The out-left moves it too far out for my right hand, and sometimes the evf shuts it off thinking my hand is my eyes. Actually the M6 tilt up or down is better for me.
DEVANSH PATEL
Wildlife Photographer
Aug 24, 2018
Ahmedabad, India
Well if I understand this post I think it should be for a mirrorless system because we are seeing the Nikon Z7 and Z6 with a really bright screens. I think it will be the answer to Nikon.
fullstop
Apr 23, 2018
1,088
151
i greatly prefer the "classic" left hinged fully articulated displays over "tilty-flippy only", no matter how the latter are implemented (worst way ever encountered is on EOS M5).
"fully articulated" displays are "really right": they work in both landscape and portrait orientation, tilty-flippy does not, it is a vlogger hack only. about 40% of my captures are in portrait orientation.
EOS M50 implementation is perfectly fine.
like all tilty-flippy implementations, Nikon Z7/6 display hinge sucks. just try it in portrait orientation and you immediately now what's wrong. :)
fullstop
Apr 23, 2018
1,088
151
in terms of "intelligent display brightness auto-adjust" all makers have still a long ways to go.
