Photoshop brush / Wacom tablet problem
DanP
Dec 8, 2014
57
13
I am using Photoshop 2019 CC, Wacom Intuos Pro M and Windows 10 (Windows 10 updates are run whenever offered). I have taken a Google road map and loaded it into Photoshop. I am using the brush tool to draw lines on the roads tracing my trip route. When I use the mouse I have no problem drawing lines anywhere on the map. When I use the Wacom pen I have no problem drawing lines anywhere except where I try to start on a road line. When I start on a road line, a circle appears around the pressure point and a brush tool menu opens and I can't draw a line. If I double tap on the line, then the menu doesn't open and I can draw on the road line. This is driving me nuts. Does anyone know what causes this problem?
YuengLinger
Dec 20, 2012
2,735
887
Southeastern USA
Have you tried drawing/painting on a new layer above the map? (Then merging the layers when you are done?)
How are you loading the map into PS? What file format is it?
DanP
Dec 8, 2014
57
13
Thanks YuengLinger. The map was loaded into Photoshop by pasting a screen print into a new document (PSD).
I tried your idea of a new layer, but it didn't make any diffenence. However, with further trials I've discovered that if I move the pen immediately upon it touching the tablet, then it works fine. If I delay slightly (which I was doing when trying to get the point exactly on the road), it brings up the menu. I just have to start to move the pen faster once it hits the tablet.
YuengLinger
Dec 20, 2012
2,735
887
Southeastern USA
That's good. If still having trouble, maybe you could try pasting your screenshot in to Windows Paint, then saving it as a JPG. Then you would work on the jpg. That should eliminate any type of formatting that might be causing the unusual behavior.
Photorex
Nov 19, 2016
259
44
Maybe this will help:
Create a PSUserConfig.txt file in the Photoshop CC Settings Folder:
c:\Users\username\AppData\Roaming\Adobe\Adobe Photoshop CC 20xx\Adobe Photoshop CC 20xx Settings\
Write the following content to that config file:
#Use WinTab
UseSystemStylus 0
I also had problems with using my stylus pen in Photoshop and found this solution which worked perfect for me.
regards
Frank
Jun 24, 2019
when I do this work I may save the google road map as a "jpg" , then I can draw on it by photoshop .
I use a cheapest drawing tablet xp-pen star G640 for photo editing in Lightroom and Photoshop.
it works well .
DanP
Dec 8, 2014
57
13
#Use WinTab
UseSystemStylus 0
regards
Frank
Frank - thanks for your suggestion. My "c:" tree doesn't appear to be structured like yours, but I'm not computer literate enough to try what you suggest anyway. As I don't have the problem as long as I start to draw immediately, or double tap to start, I think I'm OK leaving things as they are.
