Portable speedlight modifier suggestions
sanjosedave
Jan 17, 2012
200
The Neewer 9x12 reviews on Amazon report that how it attaches to the speedlight is poor, to ok, at best.
I will be using a single speedlight off camera to take portraits.
Don't have room to set-up umbrellas etc
Gary Fong-style cap, or get a Neewer and use gaffer tape?
leadin2
Apr 3, 2017
55
Try Rogue Flashbender and reflectors (you can DIY too). They have quite a few tutorials in YouTube.
hne
Gear limits your creativity
Jan 8, 2016
299
15
neuroanatomist said:
Lastolite Ezybox Speedlite.
+1
There are small shoot-through umbrella that can be hand held, but in tight spaces you lose control of the reflections. Black-backed umbrella are best held behind you (unless you've got long arms made of rubber instead of bone and muscle) which get tricky to aim and having them behind you necessitates even larger umbrella to get the same softness.
Foldable softboxes are better as long as they are well constructed. The ezybox is.
aceflibble
May 8, 2015
292
54
Ezybox if you will be putting it on a stand, flashbender (+diffusion panel) if you'll be waving it around by hand.
I also recommend you do not underestimate the versatility of the bare flash and you should spend some time experimenting with that. Look up Damien Lovegrove for examples of what one bare flash (occasionally two) can do in portrait work.
pwp
Oct 25, 2010
2,515
7
The Neewer is so cheap it's almost free so I got one to try. What a piece of rubbish. Yes, it's a horror to attach, and the light quality/characteristic for portraits & half body, looks awful...harsh brutal light. I put it straight in the bin. ???
Maybe the OP should check out the now rather famous Black Foamy Thing...
https://neilvn.com/tangents/about/black-foamie-thing/
-pw
Pookie
Don't forget to gargle private...
Nov 29, 2014
952
140
Santa Cruz, California
Probably the best suggestion here... highly recommend it. I have the small and larger versions. If you're in SJ, California I have a couple very lightly used that I could part with. PM if interested. I don't shoot with speedlites these days...
pwp
Oct 25, 2010
2,515
7
Not sure of the OP's needs. Can these be used on-camera?
-pw
