RF 50mm f/1.2L on DxOMark: How to decipher?
YuengLinger
Dec 20, 2012
2,787
971
Southeastern USA
If anyone can explain what this means in the context of other reviews, I'd appreciate the insights! For example, opiticallimits (nee photozone) is practically breathless:
DxOMark...Is the reviewer just being coldly clinical to convey objectivity? Because it seems she sees it as nothing special, just incrementally better than the ef 50mm f/1.2L.
If all you want to do is bash DxOMark generally, without any explanations regarding this specific review, please save your time and ours. If you own this lens and have true insights, or you think you understand why the results line up the way they do because of testing methodology (or lack of), please chime in!
Thanks!
koenkooi
Feb 25, 2015
668
444
I seem to recall that the DxO score has a factor for the performance when completely stopped down, which is why Canon lenses that go down to f/32 get a lower score than lenses to only go down to f/16 or f/22. Compare the 50mm f/1.8 with the 600mm F/4L II.
Reactions: Pape
neuroanatomist
24,635
2,142
Honestly, a general bash of DxO is the answer to this specific review as well. DxO’s lens scores aren’t. They are lens+sensor scores. All the higher-scoring 50mm lenses are on higher resolution sensors than the EOS R. Not a coincidence.
Pape
Dec 31, 2018
491
293
That might be true when watching what score 50mm sigma got with 5div its just 39score ,point more than RF50
Reactions: YuengLinger
Antono Refa
Mar 26, 2014
905
156
IIRC, the claim was DxO averages performance for all aperture values, so lenses that go to f/32 get lower scores than lenses than go only to f/22. Same goes for wider apertures - the 16-35mm f/2.8L mk III isn't that far from the f/4L at equivalent apertures.
Viggo
Dec 13, 2010
4,352
963
Shouldn’t that play in favor of the RF50 that “only” goes to f16.
Del Paso
M3 Singlestroke
Aug 9, 2018
680
704
Sorry, but I think DXO testing isn't even worth a single comment.
We all know the RF 1,2/50 is a fantastic lens, so, why care about DXO ratings?
Neutral
Oct 19, 2012
335
6
What is interesting are real measurements results and not lens scores.
1. F-stops vs T-stops:
Canon RF 50mm F/1.2 has only 1.5 T-stops while competing Sony 50mm F1.4 has 1.6 T-stops, which means Canonn has higher optical losses and as result there is almost no benefit in shooting low light using Canon RF 50mm f/1.2 compared to Sony 50mm f1.4. DOF is different subject.
Sony 85 f1.4 GM has the same 1.5 T- stops as Canon RF 50mm f/1.2
T-stops/F-stop ratio is what is really matters when talking about lens light transmission optical efficiency.
Canon 1.2/1.5=0.8, Sony 1.4/1.6=0.875. Very interesting.
I was expecting RF lenses to have higher optical efficiency considering all claims that wider mount diameter results in better lense optical efficiency.
2. For lens resolution efficiency (when tested on camera body) absolute resulting resolution is not relevant and does not matter as it all depends on camera sensor resolution.
Important is the overall system resolution efficiency ratio = Measured_resolution/camera_sensor_resolution
In other words how much lens deteriorate overall system resolution.
Results for RF 50mm f/1.2 are bit strange for me.
For Canon RF system efficiency is 22/30.3=0.67 ( on EOS-R) whereas for sony it is 41/42=0.976 (50mm f1.4 on a7r2)
Where are here claimed benefits of Canon RF mount system over Sony E-mount system ?
After so many discussions regarding RF mount and RF mount lenses benefits over competing systems I was expecting opposite results, a bit above Sony system, at least 0.93-0.95 whould be something good.
Maybe RF lenses are optimized for future Canon sensors for new RF bodies on their roadmap rather than for old sensor from EF mount used in EOS-R which has microlens design optimized for EF mount ?
