Rogue FlashBender 2 - XL Pro question of weight
daniela
Aug 19, 2012
239
Hi!
In winter it is the time to shoot indoors. So, blowing up my equipment is needed.
For my small working room, a second softbox would not work well, so I found the Rogue FlashBender 2 - XL Pro Lighting System in the world wide web.
My question: Is an speedlite able to carry its weight? And is it possible to bend/tilt the flash head, or has it to be used only in vertical position?
I´ve ordered the large flash bender and I´m thinking of buying the XL kit too, if I can tilt the flash head.
Thanks
Daniela
neuroanatomist
24,182
1,455
I'm sure it will be fine. I use a Lastolite Ezybox Speedlite on my 600EX, it's a 22x22cm softbox with sturdy construction, and it's not light.
Besisika
Mar 25, 2014
634
21
Montreal
I have one and it is my favorite modifier in tight space, especially when I need to put it against a wall (simulating a wall lamp).
Yes, a speedlite can carry it. Both my 430EX II and Yongnuo have no trouble carrying it.
Yes, you can tilt it. don't expect it to stay strongly straight though. It bends a bit but doesn't bother at all.
My suggestion, though, is to use an umbrella holder as the steps on a speedlite tilting is too big and getting the right angle is sometimes impossible.
I mean something similar to this:
http://www.ebay.ca/itm/Photo-Flash-Adapter-Hot-Shoe-Swivel-Light-Stand-Mount-Umbrella-Holder-Bracket-B-/331723626297?hash=item4d3c44d739:g:r0UAAOSwcLxYLwNC
