Hector1970 said:
The ink tanks are way too small.
I don't think I've ever managed to print without running out of ink.
It seems mad on a printer so big they couldn't design bigger ink cartridges.
The Pro-10 has inks mounted on the head mechanism. Larger ink tanks require to be mounted elsewhere - like the Pro-1, and that makes the feeding system more complicated (and probably expensive). I had an HP printer which often had ink feeding problems for this reason. But, yes, they like a lot making money from inks. It's not that previously companies didn't make money from films, papers, chemicals, etc. ;D
Hector1970 said:
The other thing is I can't understand between printer drivers/software and Photoshop / Lightroom why they have made printing so complicated. It's a total frustration for beginners.
Printing is hard enough to get right without software obstacles.
Printing is one of the few tasks that turns digital data into physical items, and for this reason it requires some "complications". I understand your issue, but these printers are designed to deliver the best result they could, and that requires some decisions from the user (i.e. what colour matching engine to use). Other may be printer-specific features operating systems and applications have no support for - things like Canon Pro-10 coating.
Other settings, like the paper size and type, are required because the printer can't recognize them itself. Some HP printers can (could?) read codes from specific HP papers and configure themselves, but of course it worked only with HP papers. Unless a standard is adopted, there's no other solution.
LR print interface has some design issues, and could be improved a lot. PS is designed for professional use, and takes into account professional needs.
But, again, to achieve the best results some decision needs to be made by the user. Software can do a lot, but it still cannot understand what a use really want. Part of the process is complicated because printing properly is somehow a complex task with many variables.
There are other applications that adopt Eastman's motto "you press the button, we do the rest", some I guess also come with the printer itself - look if their outcomes is acceptable for you.
The LR/PS plugin that comes with the Canon Pro-10 makes printing a little easier, while still delivering an acceptable quality.
You may quickly print with default setting - both the driver and applications, but, believe me, results will be disappointing. The HP printer I mentioned above did a lot to hide from the user the nuisances of photo printing, but I never got good results from it but in an handful of cases. I switched to a Pro-1 too, and I'm much more happy now. It may takes some time learning, and probably I still have a lot to lean, but that's part of the fun.
Otherwise I would have simply my photo printed by a printing service.
