The upcoming RF mount wide angle f/2.8L zoom will be wider than 16mm [CR2]
EOS 1D MK II
7,843
468
Canon has already mentioned that a trio of f/2.8L zoom lenses is coming in 2019 for the RF mount. It’s pretty obvious that we should expect some kind of “holy trinity” of lenses such as an RF 16-35mm f/2.8L. RF 24-70mm f/2.8L IS and an RF 70-200mm f/2.8L IS.
We’re being told that the wide angle lens for the RF “holy trinity” will be wider than 16mm. Both an RF 12-35mm f/2.8L and an RF 14-35mm f/2.8L have been developed for testing.
We have seen a patent for an RF 14-21mm f/1.4L, but don’t expect such a lens to surface in 2019. Included in the same patent is an RF 16-35mm f/2.8L and an RF 12-20mm f/2L. So we think it’s possible that a 12-35mm f/2.8L will what wins out.
Nikon will be coming with a 14-30mm f/4 S and we think Canon will definitely want to keep its lenses the most impressing in the full frame mirrorless world. As such, we expect them to a bit faster and a bit more extreme on the wide end...
Continue reading...
Talys
Canon 6DII
Feb 16, 2017
2,058
329
Vancouver, BC
Well, depending on price, and whether it comes out in an f/4 flavor later on, that could be exciting. I just don't use wide angle enough to buy a $3,000 or more flagship wide zoom.
twoheadedboy
EOS R Fanboi
Jan 3, 2018
44
43
Kenosha, WI
Yes, for sure. f/4 and can use normal 77mm filters. I would actually take a 16-35mm f/4 on the RF mount because I'm assuming it would be much smaller, but a 12 or 14mm on the ultra-wide end would be intriguing (also assuming the quality is as good or better than what we have now).
Reactions: Tom W and jd7
Del Paso
M3 Singlestroke
Aug 9, 2018
656
684
It certainly will be easier for Canon to develop a higher quality wide angle zoom due to the shorter distance bayonet to lens , no need for retrofocus design. This has often been demonstrated by Leica with their superb M rangefinder lenses.
So, I expect some very exciting new wide angle lenses (zooms or primes). This being in my opinion the main advantage of mirrorless, no gains with tele lenses.
The Fat Fish
VFX Artist
Jul 29, 2017
90
54
26
Exeter, UK
I really hope it's a sensible wide angle lens. The 28-70mm F2 is very fancy and all that but impractical (based on size, weight and cost) when compared to a standard 24-70mm F2.8. I'd have much preferred that at launch.
Reactions: MrFotoFool
As awesome as these lenses sound, I think it's pretty safe to assume that they'll wind up being roughly the same size and weight as the 28-70 f/2 RF, (or bigger!) so...
OK who am I kidding, if it's ultra-sharp even in the corners, I'd totally buy an f/2 or f/1.4 ultra-wide zoom, no matter how big and heavy it is. I might not take it on every wilderness backpacking trip, but it'd still be an epic lens whenever it's possible to bring it.
boiseblake
Feb 27, 2015
10
11
If it can match or beat the legendary Nikon 14-24 for astro landscape photography I'll buy one instantly. The coma on the current 16-35 has been less than impressive.
tiggy@mac.com
Pentax K-1000
Jan 20, 2014
512
204
Thetford, VT
www.ForestMetrix.com
I suspect coma won't be the highest priority for this set in the eyes of Canon. F/2.8 isn't the fastest aperture for astro. The priority is likely to be general use and sharpness. The f/1.4 and f/2 development projects would likely have coma as a higher relative priority. Man, that 1.4 makes me giddy with anticipation. Except it's Canon, so it'll be 3 years of anticipation.
Reactions: boiseblake
Steve Balcombe
Too much gear
Aug 1, 2014
172
32
The original 16-35/2.8L takes 77 mm filters, and one of the characteristics Canon has talked about for wide/normal RF lenses is smaller front elements and larger rear elements. This is because they are not so strongly retrofocal so they don't need such extreme negative elements in the front group which are large and inclined to be bulbous in a DSLR lens.
So maybe an RF 14-35/2.8L could have a 77 mm filter thread?
Reactions: nchoh and Aaron D
s66
Jan 9, 2018
23
10
I was hoping to get an EF11-24 but an RF wider than 16: I'd consider it and an RF body and step into the next generation instead on digger deeper in the old generation.
Now if they'd only make an RF body with proper in-body GPS at around the 5DIV (or better) level to match.
peterzuehlke
Oct 1, 2015
106
19
This brings up a question: in the days of film the Leica M lenses could be excellent and small due to non-retrofocus (non reverse telephoto) designs. But I think when they went to the M digital there was a problem with angle of incidence with the M lenses interacting with the microlenses, that had to be corrected out in firmware. Wonder if Canikon will need this kind of fix.
Reactions: Del Paso
tron
Nov 8, 2011
4,265
537
I can’t really complain about the current 16-35mm f/4 EF lens; plus with the adapters, we get drop in filters. So, not excited by an R version.
+1 Especially since there are also the excellent EF16-35 f/2.8L III and EF11-24 f/4L.
Emphasis on the ... EF ;)
Tom W
Sep 5, 2012
242
186
Canon's going to entice people me, content with our 5D Mk IV and lenses, using new, fast, sharp wide-angle R lenses. That's exactly what's going to happen here.
Jul 12, 2013
251
83
I have held off on purchasing the EF 11-24 in anticipation of something like what is rumored: a 12-35mm f/2.8L that fits the R mount!?
Oh my.
Oh my.
Oh my.
Jul 11, 2017
5
3
Although both would be interesting to shoot in my real estate photography business, my guess is that my most used focal lengths (16-20) would remain the same.
Reactions: Normalnorm
