Why isn't there a magic wand in Lightroom?
May 31, 2011
2,947
I've been using the magic wand in photoshop since 1998... so it isn't exactly cutting edge technology. I want to select a background... darken it... and leave my subject untouched...
I suppose I can guess the answer... it is because I should be using photoshop since they work best in tandem... but seriously... a magic wand... it seems silly to not have that stand alone functionality in LR.
Having said that... if it is there... and I'm merely ignorant... I will withdraw my outrage.
As mentioned, use the adjustment brush.
One partial answer to why LR does not have a magic wand is: Lightroom is specifically focused on PIE (parametric image editing) while Photoshop is specifically focused on RIE (raster image editing). They each do their own part best, and it doesn't make sense for Adobe to start mixing in the PS stuff into LR too much (although they are doing it more and more lately). The adjustment brush creates far better, more accurate masks/selections than a wand tool would, despite it taking longer and being a pain in the neck.
After the basic parametric edits in LR on my RAW, I move to PS for anything regarding selections or raster stuff.
Marsu42
Canon Pride.
Feb 7, 2012
6,310
Berlin
der-tierfotograf.de
I agree, and we can look forward to LR6 here: In ACR 8.7 for PS CC Adobe already enabled the advanced mask editing tools so it'll be easier to edit selections. They could of course also have enabled it in LR5, but then again there has to be some reason to pay some $$$ to upgrade for the non-subscription users :-o
Marsu42
Canon Pride.
Feb 7, 2012
6,310
Berlin
der-tierfotograf.de
Skirball said:
Probably not a big deal for a sidecar, but that'd mean that the catalogs will increase dramatically as well.
Not dramatically: You can look at the sidecar files (or extract the XMP:xmp-MM dng tags with exiftool) and see that LR just stores the parameters where you brushed with what brush settings and so on. Much less data than pixels and nearly independent of the image res. What adds bulk to the LR catalog is the editing history and keywords.
Interesting. So if you drag an adjustment brush does it just log a vector based on coordinates?
Keywords? Why would that make a significant impact?
It's just my observation - it's not just the kws, but the whole bulk of metadata you can attach to the shots (iptc/xmp caption, title, photog, address, whatnot). The catalog isn't highly compressed as this would slow down things, so it's a memory hog. But you can zip a 3 *gb* catalog to 100 *mb* :)
Just look at a .xmp file after saving metadata, it's easy enough to find. Adobe cooked up their own method, no idea what exact kind of math or method it is for which tool (brush, circle, linear, healing/cloning...).
jdramirez said:
Actually... LR and facebook are not playing nice together... what I'm seeing in LR is what I expect, but FB is making the black look horrible... I'm guessing it is just FB's compression...
If you calibrate your monitor, could it be that your browser is not set to use your monitor's color profile?
Calibrating your monitor is a good start, but you also have to tell your browser which color profile to use for images, too. For Firefox, I use the Color Management add-on. It works well, but you have to manually select the profile to use (I wish it would dynamically apply whichever profile is in use by Windows for the monitor the browser is displayed in). Since I move between a two-monitor setup at home and another at work, I have to switch the profiles back and forth in the add-on. It's a minor inconvenience.
If you don't calibrate your monitor, well, all bets are off... :p
2,947
I used the x-rite that was in sale a few weeks ago... I still need to do the rebate... But I'll give that a look. Thanks for the suggestion.
privatebydesign said:
It's there, or a version to do exactly what you want.
Just use an adjustment brush with Auto Mask selected. Easy.
auto mask is a bit flakey and can do some wierd things. I find its better to use the brush without automask to apply the setting and then erase using auto mask over the overlapped areas. this gives cleaner results
+1, I have yet to find a shot that works with LR5 automask - probably non-nature shots are compatible. But rejoice, as indicated in the newest ACR for PS CC the new LR6 will also have enhanced masking tools!
