AFMA - what range do you see in your body and lens combos?
drolo61
Canon Rumors Premium
Aug 31, 2012
112
5,966
Hamburg - Germany
Just calibrated my new 5DMarkIV to my existing range of lenses using FoCal 2.4.
I have
50 1,4
135 L 2,0
24-70 L 2,8 II
70-200 L 2,8 IS II
I got AFMA values between +1 to +8, with "excellent fit" for the "L"s and a relatively inconsistent focus on the 50.
Would you consider that range "normal"?
I have
50 1,4
135 L 2,0
24-70 L 2,8 II
70-200 L 2,8 IS II
Same as yours, but on 1.4 tele-extender, +12
Go into the compare menu in FoCal and it will give a chart for the range of values found by other users for each of your lenses on the 5DIV as well as your other bodies. It's a useful guide and can stop you worrying. For example, my 300mm/2.8 II is +7 on the 5DIV and was +9 on my old 7D, but I now know that these values are typical. In general, most of my other lenses hover around 0, but also find that the 1.4xTC can raise to +10.
this is a meaningless question. a body that is off by -20 and a lens that is off by +20 will together be zero, while a body that is -5 and a lens that is -5 will together be -10. that certainly doesn't prove anything about the quality control of anything. end of the day, if your pairing afmas to zero, or to +/-20, or anywhere in between, you are good. you only have an issue if +/-20 isn't enough.
Whenever I upgrade to another camera, I will definitely get a model that supports AFMA. I recently bought an ancient 1D mark II that is currently being serviced by Canon for backfocusing (something that I could have easily corrected for myself if it supported AFMA).
It was backfocusing on both my Tamron 28-75 F2.8, and my Canon 50mm F1.8 STM.
Canon tested the 50mm lens and said it was spot on (and that the camera was the problem).
Something that is often overlooked, but is a real issue is shipping damage that throws AF out on lenses. Cameras are usually closer to being in spec, but can also suffer AF inaccuracies.
I found quite a variation from camera / lens combination from lens to lens and camera to camera. Generally, most lenses were well within specification but I had a occasional combination that was far enough out to benefit from AFMA. The adjustment amount is normally different from camera to camera, but some lenses were perfect on various bodies.
I attached a old chart which compares the AFMA settings originally obtained from using one of the commercial calibration tools to using Focal on my 5D MK II and 7D. I will not buy a camera which does not have AFMA unless its DPAF, which uses contrast detect as a final tweak to the autofocus, or it did originally.
