Focus speed with R5 battery grip
GreenViper
Canon Rumors Premium
Jan 29, 2014
32
74
4,859
UK
Can anyone who has the R5 battery grip let me know if there is any improvement in focus speed, particularly with big whites. Vertical controls and the extra battery aren't enough for me to consider buying. Thanks.
The grip only draws power from one battery at a time.
On my R5 with the BG-R10 grip, the battery charge is similar on both batteries which indicates that it draws from both batteries. That's starting with both batteries at 100%. Then shoot some pictures and both batteries will indicate approximately the same lowered capacity. I just started charging two Canon batteries and they were both about 70% which indicates both were drawing at the same time. Now when you are charging the batteries in the grip, it charges one at a time as indicated by led lights. Then when both are charged, the led's go out. As a side note you cannot charge non-Canon batteries in the grip. There must be only Canon batteries in the grip for it to charge.
Are you sure the grip isn't drawing from one battery for a few shots, then from the other, to try to level the load?
That I have no idea. I just know if I check the batteries, they are both about the same. Using them back and forth doesn't make sense to me. It would make more sense to have them in parallel which would increase the current capacity.
Yes, that makes a good deal of sense, provided of course that circuitry is in there to prevent one battery from discharging into the other if the voltages are ever slightly off (like one must do with battery banks and solar arrays).
Yep I can confirm it does try to draw off them both about equally. It does charge them one by one.
I haven’t noticed any improvements in speed though. My pinky finger is always happier with the grip on though.
