Laowa introduce ultra-wide angle 9mm/f5.6 for mirrorless FF
dilbert
EOS 90D
Aug 12, 2010
169
172
There is also a 11mm/f4.5
Not available for Canon.
Antono Refa
Mar 26, 2014
1,426
514
Canon RF mount has the same flange distance as Leica L mount, and a larger throat diameter, so I would be surprised if Laowa wouldn't make the lenses available in RF mount.
Surab
Olympus OM-D E-M5II
Aug 22, 2020
52
70
Hi, I have also been wondering why they seem not release certain of their lenses for the RF mount. Another example is their 10-18mm:
https://www.venuslens.net/product/laowa-10-18mm-f-4-5-5-6-fe-zoom/
I would be curious to learn why they would not bring these to RF and given
I don't see why they are holding back on some of their gear.
SteveC
R5
  • Sep 3, 2019
    2,654
    2,561
    I imagine it takes time to develop stuff like this, and they can only do so much at once, even if the want to. Now maybe they don't want to for some reason, but the point is you can't tell.
    Surab
    Olympus OM-D E-M5II
    Aug 22, 2020
    52
    70
    I agree. I wasn't looking for conspiracies, but just curious if someone knew. Laowas lenses are pretty exciting and having them support Z mount for example is a plus for Nikon (also Sony and L mount).
    It's also confusing because some of their lenses are available. It could be something with the AE chips, but then why do they work on some of the lenses? It's a curious thing at the very least.
    SteveC
    R5
  • Sep 3, 2019
    2,654
    2,561
    This are full manual lenses without AF or aperture control.
    The camera might still refuse to operate if it cannot establish some sort of communications with the lens, even if only to find out the aperture for EXIF and discover that the lens has no autofocus. That would require knowing something about the protocol.
    SteveC
    R5
  • Sep 3, 2019
    2,654
    2,561
    I own two Laowa lenses, the 60mm macro and 15mm macro.
    Both are full manual, but you have to enable "release shutter without lens" to take pictures.
    The camera doesn´t know there is a lens fixed.;)
    Sounds like the situation with interfacing with the R mount cannot be worse! OK, in my ignorance I can only speculate that they don't see enough demand yet to make it their immediate priority.
    koenkooi
    EOS R6
    2,652
    2,843
    The Netherlands
    Their 100mm 2x macro has electronic aperture control on the EF mount, but not in the RF mount. Which is why I'd still pick the EF version over the RF version. Being forced to focus stopped down isn't something I want in this day and age.
    Antono Refa
    Mar 26, 2014
    1,426
    514
    Then I find the lack of RF support strange. Maybe its a matter of manufacturing capacity needed to make a slightly larger barrel, or arbitrary selection of which mount to support first.
    I plan to upgrade from 5DmkIV to RF, and hoped the 9mm f/5.6 would be available in RF by the time I'll pull the trigger. I naively assumed the lens would report its ID, focal length, and aperture to the camera. As it doesn't, there will be no automatic correction, e.g. of vignetting. That makes the lens a little less attractive.
    Nemorino
    EOS R5
    Aug 29, 2020
    525
    1,670
    You can choose the lens profile in LR in post. Not convinient but ok.
    Have you seen the sample pictures? If you enlarge them the IQ doesn´t look so good.
    The extrem angle of view would be imo a challenge for every lens and it is questionable to design a lens just to be the widest.
    Antono Refa
    Mar 26, 2014
    1,426
    514
    You can choose the lens profile in LR in post. Not convenient but OK.
    Not convenient, and AFAIK doesn't allow setting the manually selected aperture value. I doubt it auto-detects it.
    I think its acceptable.
    The extreme angle of view would be IMO a challenge for every lens and it is questionable to design a lens just to be the widest.
    It also accepts 49mm filters. Compare that to filtering solutions for the EF 11-24mm f/4L
    Nemorino
    EOS R5
    Aug 29, 2020
    525
    1,670
    If it fits your needs it is disappointing Laowa neither produce the lens with RF mount nor put electronics inside.
    I would like to see real world examples and hear experiences. Laowa make some strange designs: the steppless aperture control of the 15mm Makro or its useless shift-function. But although i enjoy shooting with this lens.;)
    So it is disappointing for me you cannot tell us about the lens.
    Antono Refa
    Mar 26, 2014
    1,426
    514
    Yes, I'm a little disappointed. I hope Laowa would make the lens in RF mount with contacts by the time I switch mounts.
    I assume the stepless aperture is for videographers, and the shift function is for architecture photographers. I do not presume to speak for either audiences, so I'll pass on any further comments.
    Disappointed that I can't tell you about a lens that doesn't mount on the camera I own, or that I don't summarize the reviews you can read just as well as I do? Those are some strange expectations you have there...
    Nemorino
    EOS R5
    Aug 29, 2020
    525
    1,670
    This is what someone would assume if reading only the specs.
    In practice it is different: the range of the aperture control is very small and difficult to adjust. The scale is also very small less then 4mm from f/11 to f/32.
    The shift function could only be used with APS-C Cameras (mentioned in the manual). You could only shift vertical and only +/- 6mm. Nothing in between. No scale. No possibility to fix. The disadvantage of the additional moving parts and the possibility dust and humidity getting inside overweights the advantage.
    With the Eos R i cannot use it at all, with my former 80d i tried to use the shift but the effect was always to strong.
    The reviews of the 15mm Laowa are good examples why i prefer the experience of owners:
    "The shift is said to work best on APS-C. It can be used on 35mm frame, but there is likely to be vignetting. "
    I tried it again yesterday and the shift turned a straight line into a S-shaped curve. The quoted statement is simply wrong.
