Minimum shutter and focal length for APS-C and 5DS
Desperately seeking birds
12,441
22,879
There is a good article in TDP on minimum shutter speeds and focal length of lenses.
http://www.the-digital-picture.com/News/News-Post.aspx?News=17252
The author is basically right that pixel size is the key factor, and argues and experiments that 1/2*f is a better working rule than 1/1.6*f for APS-C and 5DS/R.
Maximilian
5,711
8,649
Thanks for sharing.
I was talking to a guy at brick and mortar store lately who also does camera workshops (studio to "wildlife" at the zoo).
He told me that for a 5Ds (R) you should use at least 1/(4*focal lengh) if you're not using a tripod and the subject is not steady.
Even with a 5D3 he'd recommend at least 1/(2*focal lengh).
Feel free to think about this and make your own opinion.
4,549
448
57
Hi Zim.
You got me thinking how to incorporate age with a sensible result, seriously, my photo buddy has problems with sway, he's approaching 65
1/(2x focal length + age) or maybe 1/(2x focal length)+ 2/(3x age) perhaps I didn't express the fraction correctly, don't like 1/(1.5x age), it doesn't look right, anyone think of a better formula.
In case you are wondering maths formulae are not a real strong point for me. Perhaps it should be logarithmic or something so that at a young age it is a small ratio and as age increases the ratio increases?
zim said:
1/(2*focal length)
Been using that for some time now. Sadly it's also an age thing for some *sigh*
Thanks for sharing.
I read the article earlier, but I am of the inclination to use higher shutter speeds wherever possible. With IS lenses, shutter speed is not as critical, and for moving subjects, a much higher shutter speed is needed.
I think that trying to get pixel sharp images from a 7D MK II or a 5Ds series using a non IS lens and 1/1.6*focal length will not work for a significant number of cases. Camera and lens testers have all remarked about how difficult it is to get the full resolution the cameras can yield. I used 1/2X for my old 7D.
rpt
Mar 7, 2012
2,787
21
India
Valvebounce said:
Hi Zim.
zim said:
1/(2*focal length)
+1 for both of you. I have been using 1/(2*focal length) on my 5D3 for some time now.
10,673
6,120
The premise of the article is fundamentally flawed.
For the longest time dof (sharpness) has had a standard, an 8"x10" print at 12" viewing distance regardless of the size of the capture medium. The entire article is based on the premise that you would view a higher density image at a larger magnification ratio than the lower density image, which is daft, pixel density has nothing to do with magnification unless you view and print at 100% view (which you might do for sharpening etc but not for useful high quality images).
It is like taking images with a ff camera and a crop camera and printing the crop camera image larger than the FF image because it has more pixel density, or to take the accepted standard, you would look at a ff image printed to 8"x10" at 12" and the crop camera image printed to 16"x20" and still viewed at 12".
You have to have a standard to consider anything a comparison, in this instance the same sized output, either on screen or in print has to be the standard.
