Over-lubed zoom ring?
Ruined
Aug 22, 2013
843
14
Just got a new 16-35 f/4L (which I owned a few years back) from Amazon and the zoom ring is making an odd sound like they slopped on too much grease in the factory. Like its working out air bubbles or something whenever its turned to zoom. I've used it a little bit and sound still there. Anyone had this before? Don't recall having a lens with this issue previously. Zoom feels smooth just SOUNDS sticky :)
16,618
1,577
I don't think they use grease any more. The guides run on nylon bearings / wheels. I think you should exchange it, or have Canon look at it, there is no sense keeping a lens that is not right.
Reactions: AlanF and Joules
Ruined
Aug 22, 2013
843
14
Alright I didn't realize that. Thought it would work itself out but it doesn't seem to be improving . Really weird issue
Ruined
Aug 22, 2013
843
14
I played with it a bit more , it seems the glue that holds the zoom ring rubber to the lens barrel is defective or something. Gonna get replacement
16,618
1,577
The zoom ring has a rubber band over it, no glue, it is held in place by its elastic properties. You stretch it out and pull it off the ring to get at some of the disassembly screws. Whatever it is, the replacement will be fine.
Del Paso
M3 Singlestroke
Aug 9, 2018
1,107
1,140
Had the same issue, on 24/70 f4.
Rubber rings were held in place with 2 face-adhesive tape.
Replaced the tape with 3M (Amazon), but take care not to "overextend" the rubber ring.
Should you get new ones, warm them up before mounting, the risk of distorting them will be "bigly" reduced.
<-- start Taboola -->
