Panorama advice
Sep 1, 2014
392
85
34
Hello,
I will be spending a night on a nearby mountain peak and i have an idea of a photo i want to make: a ~250° panorama which will include sunrise, sunset and night sky in between.
I searched online and could only find timelapses but not any panoramas..have any of you done something like this?
for the more experienced panorama creators around here: do you have any advice on what to take care of when taking the photos for this? its not my first pano but this one is, i think, a bit tricky...
also..i would need some photoshop help/tutorials for the final image...
D
Deleted member 378664
Hi,
I never have done a Panorama with this kind of tricky light situation.
I would recommend to take the panoramashots 3 times (1 x during sunset, 1 x during night sky, 1 x during sunrise) and each of the panoramas in HDR.
Which focal length do you plan to use? 250° is a big range especially with a long focal length and even more so when you plan to take a multiple row panorama. During sunset and sunrise you have to be quick to avoid too big differences in lighting.
Maybe it is a good idea to begin your shots at the right end of the panorama FOV and end with the left end for mastering the differences in light.
The final touch would then be to blend the three HDR panoramas in Photoshop.
kind regards
Frank
392
85
34
Taking one panorama for each moment was also my idea..
HDR is an interesting suggestion though, i will consider it :)
i will decide on focal length on the spot when i get there, from what i remember about the location (i've been there a few years ago) i think the FL range would be 24-35mm on a crop camera, but it's not fixed :)
i will however take only 1 row of photos, as lighting will change a lot during the shots
i plan to have about 30-40mins before sunset to experiment, then between sunset and moonrise i have ~2.5h and for sunrise..well..as long as that lasts, but i should have everything figured out by then :)
also the perseid meteor shower will be on the same night, so no sleep for me :)
3,368
570
is this the sort of thing you want?
http://www.camerastupid.com/how-to-make-a-time-slice/
https://500px.com/photo/98888235/360-panorama-time-slice-of-the-bank-of-the-westminster-bridge-by-yifan-chen
If so, I have seen them referred to as 'time slice'. I have never done it myself but if you search that term you may be able to find 'how to' somewhere
31,220
13,081
I've done a few like this, here's one example:
I started with two panorama shots of Boston, from the north bank of the Charles River by the MIT campus. They were taken from the exact same spot, one at night and one during the following day. Each was a 10-shot pano at 70mm in portriat orientation (1D X, 24-70L II), although I cropped them to ~7 shots worth for this, so I could pick ends where the buildings lined up nicely. There were a few boats floating in the foreground, and I cloned those out (including the masts among the buildings). Then I converted both night and day panos into tiny planets, cleaned up the seams, pasted the day planet over the night planet, and applied a gradient layer mask.
Below are the two assembled panos. For a regular linear pano, you could just layer your three panos in Photoshop, then blend them with gradient layer masks.
31,220
13,081
The above shots were taken in late fall. I subsequently went back to the same location (which is near where I work) in a winter snowstorm, and then half a year later on a summer day. I wasn't terribly happy with the resulting merged/blended 3-scene pano, mainly because of the big difference in the water between summer and fall. But here are the two additional panos and the merged scene.
Good luck with your shot!
31,220
13,081
Labdoc said:
Hey Neuro, use transform tool to planetize the pano's?
Typical tiny planet is take the pano, make it square (resize with constrain proportions unchecked), rotate it 180°, use Filter > Distort > Polar Coordinates to make it a planet, then clean up the join.
Note that you don't have to use a pano, you can crop a single image. Also, if you omit the 180° step, you get an 'inside out' planet. For example, I took a shot from a trip to DC, planetized it without the rotation, fabricated a star field and added a moon (desaturated from my Blood Moon shot).
stevelee
FT-QL
2,379
1,063
Davidson, NC
My deck:
mnclayshooter
I love shooting - clay pigeons and photos!
Oct 28, 2013
314
Minnesota, USA
I had the same thought - I couldn't recall the vernacular term for it. As I hit google image search for time slice, it confirmed that's what I was also remembering.
https://www.google.com/search?q=time+slice+photography&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjFy6nvh9DVAhUB4oMKHWdhAw8QsAQILg&biw=1680&bih=960#imgrc=tVCm8uF5GcTqHM:
unfortunately the weather wasn't ass good as i would have wanted this weekend with a thick cloud covering the sunset on both friday and saturday nights... pity...i would have liked to get the night panorama with some meteors in it..
i will try again the coming weekend and will take advantage of the new moon and milky way visibility..
