R5 firmware 2.0 wishlist , and hoping that Canon will notice ..
Sep 11, 2012
39
13
-Direct acces to minimum shutter speed with AutoISO ( or a Safety Shift in M and AutoISO, basically the same).There are four ( !) dials, come on..!
-To speed up manual, when using *h ( exposure lock hold) in M, and changing aperture , shutterspeed should change to obtain exposure.
-Tracking should be possible in ALL AF modes.
-Direct switching to full electronic shutter, don't want to switch off anti-flicker first, I know anti-flicker doesn't work in electronic.
-Switch off sensor and close shutter when detaching a lens, instead of turning camera off, change lens, turn camera on again....
-Electronic shutter sound optional.
-Electronic shutter in 10fps optional
-Spotmetering linked to focus point.
-Flash-photography: possibility to influence brightness/exposure of EVF in Exposure Simulation Off Mode( you might be looking at a silhouette when photographing a person in front of a window, and exposing for light outside)
-Customizable Quick Menu.
-Function for the Rate Button
-Possibility to move focus point when shutter is half-pressed
-When using *h, AE lock hold, you can't at the same time lock exposure with the shutterbutton.
Just to add : I have been working with Canon professionally for 25 years, and switched to Sony 4 years ago ( A9 and A9II) , moved back to Canon with the R5, and would have been totally happy if I came straight from EOS 5 IV. But Sony had a few good things that I miss now, like working with Auto ISO, which is, when you really think about it, the first and only variable you want to have in an automatic mode.And yes, I work in full manual most of the time, but sometimes you just need the speed of A, or you want to concentrate more on the people or the surroundings then your camera.
39
13
Have you passed on the above list to CPS? You'll have much more chance that they'll notice and (maybe) adopt some of them.
I'm in Amsterdam, Netherlands, and have a very good direct contact with CPS here, but that guy tells me it's almost impossible to get it across to Japan. He reports to London, there it gets on the bottom of the pile. So I have contacted CPS USA too, and you get a polite answer , but not a real reaction. So I keep trying social media as well..:)
vjlex
EOS R5
  • Oct 15, 2011
    511
    426
    Osaka, Japan
    After using the R7, I noticed some features that would make for a more consistent experience if they found their way onto the R5:
    • Remove 30 minute time limit for video recording (even if only for 4K and lower)
    • Quick Menu customization
    • Lens Focal Length display option
    • FPS option for continuous shutter (High, Medium, and Low)
    On AF menu 4, do you have "Lens drive when AF impossible" set to on?
    Thanks! You are awesome!
    I remember seeing it recently, but never changed it. Was it added in firmware? I couldn’t find it when I just got my camera in late 2020.
    This is exactly what I needed.
    Del Paso
    M3 Singlestroke
    2,566
    3,098
    The eye-controlled AF requires additional hardware in the viewfinder, so it can't be implemented in firmware alone! :(
    You're perfectly right!
    In a semi-comatose condition (been working hard to fix my car), I thought this was the post about the R5 II's wishlist, and not about firmware...
    OOPS.:rolleyes:
    HikeBike
    R6
  • Feb 6, 2019
    229
    303
    Maryland, USA
    Glad to help! I think it has been there from the start. If memory serves, my EOS R also has this option.
    It's been there for years in the EF body series. At least my 5D3 and 1DX has it. Quite possibly also the 50D and maybe even the 10D (haven't turned that thing on for 15 years or so).
    Hi, I also just started a new thread with suggested features to be added in a new post here...
    Hi,
    I´m new in this forum but not in photography. I´m using R5 for over one year. Experience wirh the R5 and comparing to my other equipment I have some wishes for R5-firmware:
    As a wildlife photographer I´m missing absolutely the raw burst mode (ef shutter) like Canon R7 or Fuji X-models.
    For landscape and architecture photography it would be helpful:
    - add option Depth-of-field: permantentely or only is shutter button half pressed
    - add option exposure warning (zebra-warning): Also usable for photography
    Best wishes
    Boot
