R5 + RF lenses mount issues?
Ericsmith
Oct 29, 2018
13
4
Hi everyone,
I just noticed this now after getting my second RF lens (R5 and 15-35mm RF, 85mm f2 RF), but the camera mount and lens mount don't appear to be evenly parallel or flush when looking at the camera from the top down. Does anyone have this with their RF mounts as well? I only noticed it after mounting my new 85mm f2 outside and the light was shining through the gaps.
I think the enclosed pictures are much better at describing what I mean. Can anyone confirm the same or not?
Cheers
Stay at home
7,618
7,958
I don't have any RF lenses but my EOS R mount adapter fits evenly all around.
Reactions: Ericsmith
YuengLinger
Godzilla needs boxing lessons.
3,447
1,847
USA
Any chance of taking those shots again so that you have light on both sides of the mount? I'm not really able to see a difference because the dark side is not clear, and even if it were, comparing light against dark sometimes tricks the eyes.
Joules
doom
1,475
1,771
Hamburg, Germany
It doesn't look clear to me what is going on. It doesn't have to be a problem though. Maybe Canon does some calibration to make things line up with certain internals rather than the outside to account for manufacturing tolerances? If in doubt, try contacting Canon.
Aussie shooter
www.facebook.com/BrettGuyPhotography/
Dec 6, 2016
984
1,299
There does seem to be a slight difference on either side doesn't there. Does it affect the images?
zim
EOS 5D Mark IV
2,105
299
On the camera side is the outer ring part that you are pointing too actually part of the mount? In other words cosmetic and its only that which has a slight misalignment.
What do your photos show? I'd imagine visible misalignment on a lens would translate to some obvious issues in photos.
Ericsmith
Oct 29, 2018
13
4
First off, thank you for all the replies and insight. I'm going to take some test photos when I get time later. Canon did get back to me very fast and said it does not "seem" to be normal and to send the camera in for testing. They were very helpful, although the answer seemed very conservative and they wouldn't forward the pictures to a technician or what not. (to avoid unnecessarily sending in a normal camera). I guess it's to be expected due to liability.
This is why I wanted to ask if other owners experience the same.
Ericsmith
Oct 29, 2018
13
4
I could try with a video light I have to light it up, but it's hard because it's behind the grip. If you look at the bottom two pictures of each image, it's much clearer the gap I'm talking about. On my "L" RF lens with the rubber weather sealing gasket, you can see that the rubber gasket is much more compressed on the grip side, vs the non grip side when looking from the top down in the picture.
Ericsmith
Oct 29, 2018
13
4
That's what was my initial thought, as the parts are very precisely machined items. I'm not sure if it is calibration, as the gap (which is normal - just not the unevenness of it) is made by metal on metal contact from precisely machined parts, and while I'm not sure - I'm highly doubtful that can be adjusted in any way. I did reach out to Canon and they told me to send it in.
YuengLinger
3,447
1,847
USA
I was able to get a clear look at mine when I had brighter light behind the mount area. Yes, the grip casts a shadow, so maybe a backlit shot with a little fill in front?
I'm curious how the issue first came to your attention. In a way, great observation, but I know it would bug me until I had others to compare to--or a straight answer/fix from Canon. Good luck with this!
Ericsmith
Oct 29, 2018
13
4
Thanks for the reply. Yes, just trying to get a straight answer. Canon said it does not seem normal, but the answer is more of a default liability one. They just insist to have the camera inspected, which I'm trying to avoid if not necessary. They also don't want me to use the camera in case of damage.
I honestly wasn't even looking for it. The only reason I noticed it is because I just got the 85mm F2 with no weather sealing gasket on the mount, and after I attached the lens, I noticed the gap, and the gap difference immediately as light from the ground bounced up lit up the gap so I could see it clearly - just by complete fluke. If the "L" RF lens was on, I would definitely not have noticed it as the rubber gasket would of blocked the light (hence, never noticing it till now)
Reactions: YuengLinger
