rf 15-35MM F2.8L issue? NEED ADVICE!
StevenA
EOS M6 Mark II
86
173
So I was out last night making some IBIS stills tests and had on my RF 15-35mm lens. One of the photos I took shows some weird issues I'd like some opinions on:
This is a crop of the image, original was 15mm so this isn't edge of frame stuff. The focal point is somewhere above the right car, on the text in the window - looks fine. But then scan to the left and look at the writing in the window over there. Blurry - why? It's on the same plane as the writing I focused on. Same question on the 'for lease' sign.
But also - a dead giveaway, look at the rear wheel on the car in the middle of the frame - looks round. Then look at the front wheel on the car immediately behind it. Oval:
full size for reference:
I know lenses this wide have some issues as you go out from the middle, but these seem excessive? Thoughts?
SteveC
R5
1,859
1,720
Having just bought this lens last Friday, I'd love to know what's going on too. (Sorry not much help to you.)
Ramage
EOS R5
358
567
This is a crop of the image, original was 15mm so this isn't edge of frame stuff. The focal point is somewhere above the middle car, on the text in the window - looks fine. But then scan to the left and look at the writing in the window over there. Blurry - why? It's on the same plane as the writing I focused on. Hard to see in such a small image I know, but also - a dead giveaway, look at the rear wheel on the car in the middle of the frame - looks round. Then look at the front wheel on the car immediately behind it. Oval.
F2.8?
Are you using any of the in camera lens correction?
privatebydesign
Garfield is back...
9,190
3,411
120
Two different things.
The writing not being sharp could be a decentered lens element but I doubt it actually is. If you look at the building you are not parallel to it so the windows are not on a flat field parallel to you.
The oval wheel is the result of rectilinear projection distortion and is not a lens defect.
Reactions: amorse and StevenA
Ramage
EOS R5
358
567
I think I had a similar result in a couple of my earlier shots with 15-35 @15mm F2.8 handheld with slower shutter speeds. Sadly I deleted them as they were not usable. I never ran into any issue with the 15-35 on the R so I am inclined to think it is related to IBIS.
@StevenA this is pure speculation on my part but I think we might be seeing the "jello" effect reported in some videos with the 15-35. I am hoping Canon will be able to tune the IBIS for use with the wider angle lenses.
Reactions: Joules and StevenA
usern4cr
519
473
Kentucky, USA
My answer (aka: "best guess") is that you are *not* on the same image plane regarding the different areas of text you mention - you just "assume" you are.
Reactions: StevenA
Feb 15, 2020
356
253
Didn't Canon release a firmware update for the RF 15-35, that addresses the 'wobble' / 'jello' ? Do you have the latest firmware on your lens?
Reactions: StevenA
Ramage
EOS R5
358
567
Yeah, updated all my RF glass a few days before my R5 showed up. I think the edges @15mm can still be a little lose for longer handheld shots. Once I push to 16mm it is pretty much gone.
IBIS plus super wide seems to be a bit of an issue with all sensor stabilization systems.
Would love to see the results of the 8-15 or the 11-24
Reactions: Chris.Chapterten
StevenA
EOS M6 Mark II
86
173
At the time of the photo no, I had not updated to the latest firmware. Stumbled across it yesterday and did the update, but I haven't had a chance to retest and see if it had any effect.
Ramage
EOS R5
358
567
Seems like Canon fixed something in the firmware.
From the 1.07 update.
・The lens-based image stabilizer function works together with the camera-based image stabilizer function to achieve greater image stabilization effects with EOS R5/EOS R6
