*** Solved *** 600mm f/4 IS Lens case help please. Thank you.
EOS R5
4,540
435
54
Hi Folks.
I opened my Lens Case 600 the other day and found one of the square pads loose in the bottom of the box, could anyone who owns one of these cases please take a couple of snaps showing the locations of the pads.
I will be very grateful if someone could help me please.
privatebydesign
EOS-1D X Mark III
9,824
4,486
Graham, does this help? It’s off eBay.
EOS R5
4,540
435
54
Hi PBD.
Only in so far as the inside of my lid looks like this and I cannot see much detail in the lower section. I did a quick search and most of the shots were either too poor to tell or of the box closed, the one I did find with the box open and looking in had a lens in it!
I think the pad may be from the middle of the left hand ring, where there is a slight depression showing in the black backing ring, but that looks to restrict the placing of the lens hood retaining screw.
I appreciate that you tried, thank you.
EOS R5
4,540
435
54
Hi PBD.
I just had another look in my lens case, the photo you found actually did solve my problem I was misled by only having one loose pad. I now realise I am missing the two pads at the narrow end of the box, I really didn’t look off centre due to having only one spare pad, I guess one was already lost before I acquired the lens.
Again, thank you for your help.
<-- start Taboola -->
