TEAC announces the development of TASCAM XLR audio adapter for Canon mirrorless cameras and others
Canon EOS 40D
  • Jul 20, 2010
    10,379
    2,763
    TEAC Corporation is proud to announce the development of the TASCAM CA-XLR2d professional audio XLR microphone adapter for mirrorless cameras. This product is targeted for worldwide release by the end of 2021.
    The CA-XLR2d lineup is a collaboration between TEAC Corporation working independently with Canon Inc., FUJIFILM Corporation, and Nikon Corporation. The strategy is to combine the leading camera manufacturers’ know-how, and the high-quality audio capturing technology from TASCAM.
    Key Features
    Microphone adapter to add a professional audio XLR input to mirrorless cameras
    Direct digital audio transmission via a digitized accessory shoe with a built-in AD converter (only compatible for products from Canon and Fujifilm)
    Power is supplied by the Camera using the data transmission shoe (only compatible with products from Canon and Fujifilm)
    Build-in high-performance TASCAM HDDA (High Definition Discrete Architecture) mic-preamplifier achieves high-quality audio, low noise, wide...
    Continue reading...
    H. Jones
    Photojournalist
    Aug 1, 2014
    789
    1,607
    Wow, it's hard to overstate how exciting this is for a lot of videographers. It's very nice that this is a cross platform solution as well!
    Added bonus: it works even with cameras who need the mic in port. Definitely going to the top of my list for equipment at my day job, since we use R series cameras on a gimbal and this could definitely come in handy for when we need an audio solution for the R series cameras.
    On top of that, I'll definitely be getting one for my R5, and it adds a bonus that future cameras like the R3 will power it and accept additional channels through it.
    Very exciting time to be working in video.
    10,675
    6,120
    How would it be compatible with the R5?
    Read the press release! It says “With the included 2 x AA battery box and cold shoe mount adapter, CA-XLR2d also works with existing cameras which don't have the Multi-function hot shoe by connecting an analog audio cable between CA-XLR2d's analog out and camera's mic-in.”
    So put batteries in it and use the included cold shoe mount adapter, then connect a cable.
    Of course it does mean people who like cages for their video rigs need to have hotshoe access for the R3, it will be interesting to see how the third party cage manufacturers allow for this. Smallrig already do this for their 1DX series cage.
    Reactions: 5 users
    325
    270
    Can they get of the 30 minute limit in the R3 then.
    Can they? Absolutly. Will they? Probably not.
    There was a time when this would have been interesting but now that I have tried 32bit float I don't want to live with out it. What would be interesting is some thing like the tentacle sync that would sit on the hot shoe and send time code to the audio channel. If I am really going crazy, if some thing like this that did 32 bit float and time code so a Tentacle Sync E with just one XLR that sat on and fed audio through the hot shoe would be the bomb. Then again why doesn't Canon stick real time code in their high end hybrids. If BMD can do it with the BMPCC at half the price of an R5 then I don't see why Canon can't do it.
    DBounce
    Canon Eos R3
    May 3, 2016
    488
    527
    This adapter supports wide dynamic range audio which is 32 bit float. Read the OG press release. Not this truncated version that leaves out key features:
    10,675
    6,120
    It's about time...Sony and Panasonic already have XLR shoe-mount adapters for their mirrorless cameras.
    That is as maybe, but there is no doubt having actual specialist companies deal with the hardware in conjunction with the primary manufacturer is invariably a more solid solution. TEAC will do a better job of this than Canon, Fuji and Nikon would, Sony and Panasonic have much longer histories in the audio world so had the ability to leverage that knowledge.
    Same with Atomos and the V+. Makes you wonder what a high mp R1 with an Atomos V+ and a TEAC XLR adapter will be capable of....
    calfoto
    Long Time Lurker
    60
    65
    "Power is supplied by the Camera using the data transmission shoe (only compatible with products from Canon and Fujifilm)"
    There will likely be a solution for other EOS R cameras after the initial products are released, just based on the language of the press release.
    But the R5 doesn't have the "Data transmission shoe" that is one of the updates on the R3 - So I'm thinking it's unlikely this new Tascam adapter would work directly. There are however other Mic pre-amps available, but they input via the Mic In connection which is analogue, not digital.
    10,675
    6,120
    Exactly, they do have another version which would work with the R5, albeit via analogue
    Or, READ THE PRESS RELEASE! Or if you can’t be bothered to do that read the one paragraph from the press release I pasted above....
