Hi everybody!
I have noticed that the central part of the top plate around the hot shoe ( it covers wi-fi modules, hyroscope etc) is slightly wobbly at the far edges and does not fit tight with the rest of the top plate near the lens mount ( its edges protrude slightly above the rest of the plate around 0,5 mm). I can press it by the sides with fingers and see how it plays a bit. I have attached a photo, where I circled the slightly protruding part ( the photo shows the plate from one side only, but the other side is the same). I have asked CPS and they say that it is normal. I, however, doubt it and am afraid of potential sealing issues.
I would kindly ask the r5 owners to check if their plates are the same. Please check before you say "zero play in mine"
) ( there are always people who say about zero play, when there is obvious play due to construction like with the IBIS rattle of stabbed lenses and bodies)
Thanks!
Thanks!
