Tilt & Shift Fan?
AcutancePhotography said:
I would not have initially considered that to mean tilt shift. ;D ;D
I've been playing with my TS-E 24mm lately and just bought the TS-E 17mm, so I have Tilt/Shift on my mind ;D
I have been dreaming about getting a tilt shift lens. I think that would be a lot of fun.
They are great once you get past the initial learning curve. It's actually somewhat difficult to go back to normal lenses after you use T/S ones and you wonder why all lenses can't be T/S :) If you can borrow or rent one, you owe it to yourself to try one. I borrowed one from CPS before buying my first one.
After having bought 5 tilt shift lenses I can fully understand your statement above :) Same for me.
I'm rather tempted to buy the rest of the T/S lenses, but will wait for Photokina in case the rumors of new ones being released are true.
Mac, do let us know how you feel the 24mm and the 17mm are different, and how they overlap.
I knew I wanted a TS lens, especially since I don't like perspective distortion and end up losing resolution and cropping. Also, the effect of selective focusing has always intrigued me.
But I wasn't sure if I want the 24mm TS-E or the 17mm more.
Pros for the 17mm include: wider angle will work better for the highrises that are my first goal. I work in a highrise complex and all the buildings are quite photogenic, especially at night. Also, I like indoor architectural photography a lot. If were to make photography my profession, this probably would be the most likely way.
Pros for the 24mm include: easier maneuverability, ability to use filters, and shallower depth of field.
Questions for the pros:
1. Do you expect restriction of movements with the 17mm + TC if you use a Lee adapter and 82mm screw-in/100mm square filters?
2. How much selective focusing is possible with the 17mm? How about 17mm + 1.4x and 17mm + 2x?
Thanks
@ sagittariansrock
Regarding your first question, a very quick & dirty test with my Canon 17 TS, 1.4x TC III, and the Lee adapter for the 17mm TS exhibited just a small amount of soft (non-mechanical) easily-correctable corner vignetting starting at about 10-11mm of shift. With a 1.4 TC hard-mechanical vignetting was never observable throughout the entire 12mm shift range. Of course without the TC, the 17mm adapter will start to (soft) vignette at about 5mm of shift and will become hard-corner vignetting at about 7mm.
I'm not sure what you mean by "...and 82mm screw-in/100mm square filters". The 105 screw-in (polarizing) filter and adapter-ring?
JustMeOregon said:
@ sagittariansrock
Thanks so much for this information. I wasn't sure whether adding the TC alters the vignetting characteristics and you have completely resolved the question.
Regarding the 82/100- it was a bit of mistake. I was actually thinking of a DIY adapter that allows an 82mm screw in filter at the front end of the lens. But I don't presume a lot of people use that route.
I chose the 24 mainly because I use a polarizer a whole lot here in Florida and I had the luck to get it during a refurb sale as well. I find it too narrow for most interiors without stitching but have shot up to 20+ story buildings with it (see the three somewhat sloppy [aka personal work]) examples below). The problem is that you have to get a good way from the building and sometimes, streets & buildings (in photo 2), water (I'm watching for alligators in photo 3), and such get in the way and limit your compositions. I'm happy to say that the 17mm is much wider and should really help in that dept. I didn't have much time to play with the 17 last night (my mother in law is coming, so my current Honey-do list is rather long...), but they seem very similar but I know the 17mm has slightly less range in one of the movements. Given the huge angle of view, that shouldn't be an issue. As for filters, I'm sure I'll go the Wonderpana direction, mainly for the ND filters. I use them a lot to blur water, people, and cars for exterior shots.
I'm smashing myself against the door to the Florida Supreme Court to get everything in frame for this photo. Something the security doesn't find too exciting, even after hours:
I'm trying not to fall into the water here and I had to use the 1.4x to get better framing. Also, note that a ND32 filter was used - and poorly as the fountain somehow disappeared:
mackguyver said:
One more thought on the TS-E 17 - the lens cap is awesome! It's so much better than the 14L II that I had. I put the 17 and 24 on the 1D X & 5DIII last night for comparison and they are far more alike than different, but the test will come when I shoot with them both this weekend. I'll post some shots...
Just a comment on your pictures you posted: it is natural to have converging lines in perspective; it's how we see things as they get further away. I can still remember my art teacher showing me this at my first school ! Correcting this fully in shift gives a very unnatural image that isn't actually correct.
Sporgon, you're right, and I guess I wasn't clear in my post - these were meant to be examples of when I was limited by the 24mm focal length and are poor photos because they were done when I was just fooling around with the gear walking around or on vacation. My paid shots are done with far more care and I I tend to correct fully and then back off just a bit to avoid the unnatural look. I also avoid shooting straight on from unflattering angles like this, but I appreciate the feedback.
I could see they were just snaps, but I do see quite a few shots by others that are over corrected in shift; it's a pet hate of mine !
I can understand and what I hate are the ones where the top of the building is larger than the bottom :o
Sporgon said:
........ I do see quite a few shots by others that are over corrected in shift; it's a pet hate of mine !
I agree 100% with both of you, the look is so unnatural, my brain just knows it's wrong.
However, here's an example, I could never figure why it got printed or displayed, or even why the photographer shot it this way, he certainly knew exactly what he was doing, why he shot that way and what the print would look like.
From the first time I saw this photo, I did not get "IT", I still don't.
Photo credit, hot linked from
