Travel Tripod help wanted
tomscott
Photographer & Graphic Designer
Hi Guys,
I was wondering if anyone has any experience with small travel tripods? I took the SLR gorilla pod with me on my last trip and it was great but the balls kept poping out the sockets when tightening down, seems low quality for its cost. It was frustrating to get a good perspective when there is nothing to put it on but ground level.
The specification I want is to take either my 5DMKIII with 24-105 or 16-35mm so around 2kg. Ideally under 1.5kg, max of £150 (which means no CF) and as small as possible folded.
I have had a little look around and have been quite taken with the Mefoto products, the Backpacker or the roadtrip version.
Backpacker
http://www.mefoto.com/uk/products/backpacker.aspx
Roadtrip
http://www.mefoto.com/uk/products/roadtrip.aspx
The main difference is that the roadtrip is bigger it gets to 5FT, It can get lower to the ground, has an inversion option, both have a monopod built in. The backpacker is a great size but and has a load weight of 4kgs… the size of the Roadtrip makes it more suitable.
One issue I have seen is with the ball head, it looks great quality and spec, it has 360deg panning with a degree scale, tension nob etc but the locking mechanism on it isn't perfect. Basically a Arca-Swiss Style (PU50) but you place the camera on, screw it in, once you have screwed it so far it locks the camera like a normal locking plate but there isn't a release mechanism so if you un-tighten camera without a strap attached to you it could very easily fall off the tripod when releasing as it takes both hands. I also don't really like to use straps so this could be an issue for me.
Better explanation here at 18:52
https://youtu.be/aGALkcWPIhg
I was wondering if anyone could
A. give me any other experience with any travel tripods
B. if anyone has a Mefoto tripod in either spec would love to hear your opinions especially on the ball head whether it is actually an issue?
C if I go for the mefoto I will change the ball head for another, but this is a bit of a minefield for me. tripods are definitely not my strong suit so if anyone has any info on ball heads that would be great.
Cheers
Tom
Maximilian
5,707
8,639
tomscott said:
Hi Guys,
Hi Tom!
When I was looking for something similar I ended up buing a Velbon Ultra LUXi tripod with a threeway head
Mine is no longer available but it was similar to the Velbon Ultra 455 or 555.
http://www.velbon.biz/product/ultra.html
I'm still fine with it fot the price and if it's not too windy and has a steady ground I sometimes use it with a 100-400L.
But that's at the absolute limit and quite shaky.
Had the Backpacker as my do-it-all tripod and got some really good pics with it while on vacation this past summer. But it wasn't great for when at home and wanting to really nail it so I sold it and got a non-travel-friendly tripod.
With that, I'm about to get a MeFoto Day Trip (the tiny one) for travel. Won't be perfect all the time, but the ultimate in travel-friendly. Figured 2 tripods do-it-all where just one didn't.
And MeFoto is a great company.
docsmith
1,242
1,192
I have the Gitzo GT1542T with a Markins Q3T ballhead. It has been everything I wanted for both hiking and airline travel.
Gitzo recently released a new set of travel legs, even lighter. If I wasn't already happy, I would be looking at those. I also have seen the Really Right Stuff tripods in action and am impressed. For travel, they have the TQC-14.
Vivid Color
437
I have the MeFOTO Roadtrip in carbon fiber and have taken out on a couple of lengthy trips. So far I have been very impressed with it. My original tripod dates to the 1970s, and had no Arca Swiss plate, so I don't perceive an issue with the plate on the roadtrip tripod – – I just assume you have to be very careful and use two hands when removing the camera. That said, I agree that a long camera neck strap can get in the way when the camera is on a tripod. Recently, I received a Peak Design hand strap as a gift, and will likely put that on the camera when I'm going to use it on a tripod in the future. By the way, I highly recommend the carbon fiber version of the roadtrip tripod.
31,202
13,073
While I agree (and I may know where you've seen at least some RRS tripods in action), the OP mentions a £150 max. I think that might be sufficient to cover an RRS lever clamp, which certainly fits the weight and size requirements, but without legs it is probably not the best solution. ;)
CurtL5
Purchaser of a little, Admirer of a lot
I use the MeFoto Globetrotter pretty extensively on my 5DMiii. The ball head is basic but I cannot complain - it is secure and smooth. I stand 6'4 and seldom have an issue with it being too short...
I picked it up on a going out of business sale at a local retailer for quite a screaming deal but it normally retails around $369US.
I'd buy one again... :)
D
Deleted member 91053
tomscott said:
Hi Guys,
Backpacker
Roadtrip
Cheers
Tom
Do you mind second-hand?
The reason I ask is that a few months ago I picked up a very nice nik Gitzo G1550T (traveller) for £140. It's light (carbon) stiff (Gitzo Carbon) and does a very good job with my 1DX and 16-35 or 24-70. Mine came from Fleabay, you might have to be patient (I wasn't!) to get the right price but it is well worth a look.
I'm thinking that if he (video) were to have the tripod standing by itself instead of holding it, the camera would be in one hand and be tightening the knob with the other. He was holding the tripod and camera together, maybe just to make his point. Looked sturdy enough after setup and appears MePhoto put quite a bit of effort into the design.
I have experience with the 1-series and 2-series Gitzo travel tripods. Both are about 17" long (~43cm) without a ball head attached. The 1-series is super light. The 2-series is light, but a lot more robust than the 1-series. Both are high quality, steady, and are fine for your specified gear, although the 1-series will wiggle in strong wind. I recommend both. I have shot my 500mm lenses on the 2-series and it works fine for that use. If I had the choice, I would pick the 2-series because it is more versatile. However, if weight and size were the prime consideration, the 1-series cannot be beat. By the way, both will fit inside my standard-size backpack.
brad-man
Semi-Reactive Member
Jun 6, 2012
1,673
580
S Florida
scottkinfw
Hi Guys,
Backpacker
Roadtrip
Cheers
Look at this:
HEIPI 3 in 1 Lightweight Travel Tripod​
