Adorama has launched an exclusive electric scooter, the Slidgo X8.
Scooter Features
- Powerful 36V, 350W motor with 700W peak power
- Maximum speed of 19 mph
- Interchangeable batteries – choose between the Slidgo 10.4 Ah battery with
- 16 miles of range or the Slidgo 12.8 Ah battery with 20 miles of range
- IP54 waterproof rating
- Double braking system with rear disc brake & foot brake and E-ABS front brake
- Energy-efficient ride modes – Eco, Beginner and Sport
- Quick and easy fold design
- Puncture-proof solid tires
- Scooter weight 30 lbs. including battery
- 1-Year Warranty on the Scooter
Battery Features.
- 12.8 Ah battery pack with 20 miles of range
- Transportable, weighing only 5 lbs
- Fireproof & Waterproof
- Built-in charging port
- Highest quality Panasonic 18650 cells
- Charger output: 121 W, 42 V DC
- Charger input: 100-240 V AC, 50/60 Hz
- Charger current: 2.9 A
- 6-Month Warranty on the Battery
Check out the Slidgo X8 at Adorama
From Adorama
An electric scooter is the right choice for anyone looking for the freedom to get up and go, but with Slidgo you never have to compromise on range or power. The Slidgo X8 scooter comes with a powerful 36V, 350W motor with 700W peak power, giving you up to 19 mph speed. Choose how far you want to ride by selecting the scooter that is right for you – You can get the Slidgo X8 with either 16 or 20 miles of range.
With the ability to switch batteries, Slidgo X8 is the ultimate option for any rider looking to go further. Bring an extra battery and swap it out in seconds, with Slidgo you are always ready to keep moving. The batteries charge in only 4 hours and they charge separately, which means you don't need to lug the scooter around to power up.
Go Wherever You Want To Go.
The Slidgo X8 makes it easy to get around in style and comfort. The quick-fold design and easy-to-carry build maximizes portability so you can bring your scooter with you anywhere you need to go.
With a simple push, the accelerator button gets you going, and you can choose between Eco, Beginner and Sport mode. The LCD display gives you an easy view of speed, mode and remaining battery power.
Stay In Control.
Whether you're commuting in a busy city or riding just for fun, Slidgo X8 is designed with safety in mind so you can focus on your destination. With a front LED light and a rear LED brake light, the X8 helps you stay visible in traffic and avoid any bumps in the road. A front electronic ABS hand brake, and rear disc brake and foot brake make sure you are in control. The tires are puncture-proof, so no need to worry about getting a flat!
