Anton/Bauer Titon Micro 90 V-Mount Lithium-Ion Battery $220 (Reg $347)
Richard Cox
1 Min Read
For today, only B&H Photo has the Anton/Bauer Titon Micro 90 V-Mount Lithium-Ion Battery on sale for only $219.50, saving you $127.
Features include;
  • 98Wh Lithium-Ion Battery
  • Supports up to 10A Continuous Draw
  • LCD Battery Capacity Gauge
  • P-Tap and USB Accessory Ports
Power your V-mount camera or other power-hungry pro video gear with the ultra-compact Anton Bauer Titon Micro 90 V-Mount Lithium-Ion Battery. This lightweight battery is smaller than the original Titon series models and features lithium-ion chemistry and a V-mount. It provides up to 10A continuous draw and has a 98Wh capacity.
At the side of the chassis, a five-stage LCD screen shows battery capacity in percent remaining, and when put under load, it shows the exact remaining runtime. Using the 14V D-Tap and 5V USB ports you can power essential accessories on your rig or other small electronics.
Using a separately available dual-battery Micro plate, you can boost your runtime and the batteries can be hot-swapped without needing to turn off your camera. You can also utilize a separately available, compact P-Tap charger since the P-Tap ports can also be used to charge the battery.
Follow:
Leave a Comment
Leave a Reply
