B&H Photo has the Bolt VM-160-V2 LED Macro Ring Light in their DealZone for only $39 (Reg $69). This is a great option for anyone looking for a budget macro ring light.
Purchase Options
- Bolt VM-160-V2 LED Macro Ring Light $39 (Reg $69)
Overview
- Full Flash Mode uses all of the LEDs and turns on for approximately half a second when the camera shutter is released.
- Left and Right Flash Mode illuminates only from the left or right half of the LED ring for more dramatic lighting.
- Light Mode activates all of the LEDs for continuous lighting to see exactly where the light will fall as well as for shooting video.
- Brightness Adjustment provides 8 output levels from 1/128, 1/64, 1/32, 1/16, 1/8, 1/4, 1/2, and 1/1.
- Sleep Mode turns off power after 30 seconds to conserve battery life.
- 5500K output, includes filter for 3200K color temperature
- 1/100th sec exposure time
- Eight threaded lens adapters: 40.5, 52, 55, 58, 62, 67, 72, and 77mm
- Illuminated LCD display
- Operates on four AA batteries
The VM-160-V2 LED Macro Ring Light V2 from Bolt offers a lightweight on-camera macro light, ideal for macro photography, that provides high-output lighting for up-close shots.
Easily select between eight power output levels from 1/1 to 1/128, and dial in the ideal illumination to shoot macro images or video of flowers, insects, jewelry, and more.
The VM-160-V2 provides bright illumination using 18 high-output LEDs and has the ability to use the entire ring light or either the right or left side.
Purchase Options
