5D Mark III Silent Shutter Mode Problems
  • Thread starter Thread starter shaunsimpson
  • Start date Start date
S
shaunsimpson
Hey everyone!
My first post here...
I was doing a location shoot on the weekend, my first day out with my 5d Mk III; since it was an office location, I decided to test out the Silent Shutter Mode. It worked well, and was quiet enough that a few people in the office asked if I was actually taking photos.
The problem I noticed, was that every few minutes of shooting, the camera would lock-up. However, everything seemed to work, except the main shutter button. Even after powering the camera off, and powering it back on, it would not fire. I had to pop the battery out each time in order to rest the camera and regain functionality.
I've replicated the error on both 'Auto' mode, as well as manual modes, using the Canon 24-70mm lens, and 430ex flash. It seemed to happen about once every 20-50 shots.
Anyone else notice this problem, or able to replicate it?
Cheers,
Shaun
If I were you I'd have it replaced rather than finding a solution yourself coz it will be a big trouble for you if that gets worse in the future when the warranty is already out and one thing more if you keep the camera for some time(lets say a couple of months) and that problem shows up again if you go to the supplier most probably they will send it for repair instead of replacing it with another copy.
Drizzt321 said:
Ryant said:
There are 2 silent modes? Whoa i missed that.
Probably referring to single shot or continuous shot.
And in terms of locking up, was the memory card light on/blinking like it was writing a lot of shots to the card? Or after a short while it then started to take shots again?
There are two settings, Mode 1(continuous) and Mode 2 (Single Shot). Those are what I'm referring to. I have used both with no hangs.
I'd remove the CF Card, and after copying all files, do a low level format in your computer. That can fix card issues that cause the camera to freeze. If you have a SD card as well, a low level format can be done in camera for the SD card only. I'd do that to remove card issues from the possible list of causes. Then, see if it still happens.
I have not seen this issue with mine, I've only really been trying it on silent mode continuous and done around 500 shots this way.
However, I do think you should take it to the dealer ASAP, I suppose you haven't had any problems when shooting in any of the "normal" modes?
I had that problem on the past, and was me pressing the depth of field test button that is in a place that a person with a bug hand can press without notice it.... But after. Got used to it, all goes fine, no lock ups, and I have being shooting hundreds sof them in that mode.
