Backup body for extreme environment
hi everyone, I'm going to be living and working in Antarctica soon and I'm looking for a good backup body to take with me. My main body is a 7D mark I which I love and has pretty much everything I need.
I would be looking to use the camera for a range of uses across various environments (at sea, Falklands, peninsula, mainland continent, icebergs, low-light, astro, birds etc.) and would ideally need to be weather sealed and cold weather tolerant (-55 Celsius).
I'm going to be down there for 18 months so although my main body will be used most, it is a long time and all gear breaks, there is obviously nowhere to get it fixed/replaced should I need to.
I was thinking about getting a FF backup and wasn't entirely ruling out a nice and cheap 5D mark I, it's obviously old now but still an excellent body. I had even considered all the way up to a 1Ds mk III, so a fairly flexible budget.
It doesn't need to be FF but already have a great APS-C body so something different wouldn't do any harm and weather sealing would be very much preferable when I'm up in the more northern wetter areas.
Any suggestions?
Stock up on batteries. They will die very quickly in those temps. I'd recommend getting a second camera that uses the same batteries. Either a 7d or 5d2 maybe? I would usually recommend the 6d over the 5d2 but I think the weather sealing is better than the 6d
Any suggestions?
Another benefit of the 5d2 over the 6d for you is the 5d2 and 7d both use compact flash too
Hi,
Have you considered one of the Olympus Tough series p/s cameras? You can put them in an inside pocket of your parka where the humidity would kill any DSLR. They are waterproof and will work in colder temperatures than the DSLRs. Obviously, no where near the picture quality, but they do make a compact emergency backup.
Thanks for the replies. Certainly the sharing of batteries is a major bonus the 5d2 has over the 1d series or the 5d1. I will certainly be taking plenty of batteries and fortunately I will never be far from a source of power.
Ideally I would like to use CF cards rather than SD but will have a gopro which obviously uses SD for storage.
A friend took a 5d2 which served him well while he was out so I know this would be the safest option for reliability and compatibility with the 7d.
I had considered another 7d but would rather have a different body mainly because I was considering the advantage the FF offers.
I think I will probably take along a cheap PS as an emergency backup too.
All things considered, it would probably be a 5d2. I agree a 5d3 would no longer be a backup and would be used alongside the 7d.
I've experienced astrophotgraphy gear packing up due to sub -10C temperatures.. test all your gear at low temperatures before you go. (be careful about bunging lenses in the freezer.. you won't like the amount of condensation they suffer when you take them out)
Take ziplock bags.. when a camera gets cold, bung it in the bag before taking it indoors.. then condensation will form on the bag and not the gear. Once warm you can take it out and there should be no problems.
Read what those who've been have done. just a quick google brought up these:
http://blog.quarkexpeditions.com/what-photography-gear-you-should-bring-to-antarctica
http://antarctica.kulgun.net/Photography/
Also don't discount film.. less electronics may be a good thing... just a thought
Half the (then) new 5D2 bodies quit working on our first landing in 2009. Conditions were steady drizzle, temperature about 40F. Some of those came back after drying out, some were bricked.
Absolutely use a plastic bag for an hour or two when bringing equipment indoors.
7D2 and 5D3 are the best weather-resistant (NOT proof!) bodies short of a 1D4 or 1DX.
Not all lenses are weather sealed, many of those that are require a clear filter of some sort to complete the sealing.
As one who regularly works in extreme environments (I'm typically on the ocean 100 days a year), I'd recommend you look into the 1D series of cameras. You mentioned you were already considering the 1DS III. It's a great choice. (I own three). Or, for the price of a 7d or used 5D2, you could get a 1D III. I know it's only 10 megapixels or so, but it has 10 fps, autofocuses great, is good for up to ISO 3200 and works just about anywhere.
And, the batteries are good for a couple thousand pictures in most conditions and keep their charge as well an any out there. Of course, to be on the safe side, get a spare.
I had an OM-1 that still worked at -60C.... Film cameras were tough!
Don't forget hard cases with foam padding. Pull your camera out, take a picture ( or 50), and pop the camera back in. It will loose heat a lot slower that way, and when you come back in, leave the case shut so the gear can slowly warm up without condensation.
Don't take a chance, dump the 7D and get a 1D series body. The 1DM3 will take a much better picture IQ-wise than the 7D. A 1DM2 will be significantly better both from a reliability standpoint and image quality. You can pick up late mode serial number 1DM3s for around a $900 now.
You can drop kick a 1D body and it will probably still work, try that with a 7D and then go pick up the pieces.
Yes better weather sealing
No.. promised temperature range is still 0~40C.. On a pro-body, come on Canon, the automotive industry insists on -40~+85C.. why is your pro gear on the same temperature range as a TV?!!!
Any suggestions?
1Ds MkIII.
I use them and for adverse conditions it is far and away the best bang for the buck, and the IQ, especially at low iso, has not yet been bested to any degree by any Canon camera.
[/quote]
My husband and I have been to Antarctica (including So Geo and the Falklands) twice with three 7D bodies between us and they all functioned flawlessly both times. We've also been to Hokkaido in winter (which was actually colder than Antarctica -10 to -16 Celsius on some days) and still the 7D's performed without a problem using the precautions that have been suggested for cold weather photography. Our 7D's have been to Wrangel Island, Siberia, Svalbard, and Homer, AK and tolerated the snow and cold in those areas without a problem. However you will be in Antarctica in winter so you will have greater cold demands so perhaps a 1D series may perform better under those ultra extreme conditions. My 7D finally failed after visiting 7 continents and with 260,000 clicks (rated for 150,000) so I really got my money's worth out of it--but it never failed me because of cold, wet, hot, sandy weather--just saying..
Catherine
What weight or space restrictions are you going to be dealing with? You're much better off having 3-4 1D bodies (mk2/mk2N/mk3) than a single 7D. There are days you'll want the higher MP or iso ability, but for day in day out rough, using a 1D will be more resilient. 18 months, damn, not sure I could do that length of time.
privatebydesign said:
1Ds MkIII.
So true on the 1DsM3. Best low ISO camera I ever had. Better than the 1DM4 and the 5DM3. I think I am going to pick one up.
Photographers have had successful Antarctic trips with just about any camera you care to mention. I went for six weeks in the 1990's and was glad to have a couple of nice new Nikon F4 bodies, plus a very
cool little Nikon L35AF http://www.kenrockwell.com/nikon/l35af.htm If I was going today I'd be taking two 1-Series and a classy compact.
But from the perspective that it is an incredibly expensive, almost certainly once in a lifetime trip, why take a chance with an aged or cheapo body? It's not difficult to travel first class with this. Think entirely in terms of 1-Series Canons. If you're on a tight budget, buy low-milage pre-owned and then re-sell them after your trip. You probably won't drop a penny on the deal and you'll have the security of shooting with 1-Series bodies.
-pw
I have used my 7D Mark I in nearly every extreme circumstance there is:
Temps at -14°F through 102°F (-26°C - 39°C)
Howling wind at over 60mph
Rain
Sleet
Snow
Hail
Fog (w/ sealed lenses)
I've dropped it a few times, even. I haven't actually used it literally in a hurricane, and I haven't used it at -50 near the north pole shooting Aurora (yet. :P) I've got over 100,000 exposures on it at this point. Personally, I think most cameras these days can handle the extremes pretty well, if they are properly sealed. I'm not really sure how much the various different "levels" of sealing matter...I know some brands tout better sealing than others, but my 7D doesn't have top of the line sealing, and it's still pounding away, a dedicated workhorse.
The ONE thing you might have trouble with is shutter actuation and battery life at -55°C. My 7D gets fairly sluggish and sticktion-prone at -25°C. I haven't noticed that yet with my 5D III, which has been used in similar cold. Batteries also get pretty sluggish in the cold. Weather sealing wise, I think you'll be fine, but you might want to see what the pros who shoot penguins and such at the Falklands do about that. Some mirrorless cameras with electronic shutters wouldn't have the shutter problem, but the battery problem, that's likely fairly universal.
