B&H Photo has the GVM SD200D Bi-Color LED Monolight in the DealZone today for $149 (Reg $399).
With a high-quality COB lamp bead design, the SD200D Bi-Color LED Monolight from GVM features a 3200 to 5600K color temperature and a high CRI/TLCI of 97 to ensure accurate color reproduction.
This monolight is a sturdy aluminum-constructed fixture suitable to light up most applications and creative scenarios. The SD series is equipped with a built-in fan that delivers efficient heat dissipation and quiet operation at all times.
Compact and versatile, the SD200D measures only 13.7 x 9 x 5.2″ and conveniently allows onboard and remote control.
GVM SD200D LED MONOLIGHT
- For Video Production and Vlogging
- Output: 64,600 Lux at 3.3′ w/ Reflector
- 3200-5600K CCT
- AC Power
- Onboard, DMX & App Control
- CRI 97 | TLCI 97
- Fan Cooled
- Bowens S Accessory Mount
- LCD Display
- Includes Reflector, Power Supply & Bag
The GVM app lets you control the unit over Bluetooth right from your smartphone. One or more devices can be controlled simultaneously.
Besides that, you can make quick changes locally using the stepless adjustment dial and its LCD display. For advanced users and more complex studio setups, the SD200D also enables DMX-512 control mode with 8-bit precision.
The unit is 180° tilt-adjustable with an included yoke and runs on universal 100 to 240 VAC. Bowens compatibility allows it to be used with a wide range of modifiers.
