B&H Photo has the Litepanels Lykos+ Bi-Color LED Light in their DealZone for only $88 (Reg $699). That is a crazy savings for a product that is well reviewed. It's a no-brainer if you're in the market for an on location lighting solution.
Litepanels Lykos+ Overview
- Color 3200-5600K, CRI/TLCI: 96/96
- Measures 10 x 6 x 2″, Dims 0-100%
- Optional Bluetooth Module
- AC or Optional NP-F Battery Power
ith its compact 10 x 6 x 2″ form factor and color, light intensity, and power options, the Lykos+ Bi-Color LED Light from Litepanels is the perfect light for location or impromptu shooting. The Lykos+ has color temperature that's variable from 3200 to 5600K with a high CRI/TLCI rating of 96/96 – your assurance of advanced accuracy in color rendering.
The light is dimmable too from 0 to 100%, and while you can adjust the power and color on the fixture, you can also do it wirelessly via a separately purchased Bluetooth dongle. Other valuable features are the Lykos+'s power options. You can use the fixture worldwide with the included AC adapter, but it will also run on optional NP-F-type batteries when AC current is unavailable.
Benefits
- Lightweight, slim design with a handle on the side for precision adjustment
- Color temperature and brightness dials at your fingertips next to the handle
- Optional Bluetooth dongle supported for adjusting color and brightness via an iPhone app
- 48 SMT LEDs (Surface Mount Technology), designed for improved optical efficiency
- 96 CRI: high color accuracy
- Over 2100 Lux max brightness at 3.3′ (daylight color temperature)
- Adjustable color temperature: 3200-5600K
- Flicker-free 0-100% smooth dimming with no color shift throughout the entire range
- Color LCD display on the rear
- L-Series battery mount
- Two 1/4″-20 mounting threads are available: one on top, one on the bottom
- Cold shoe for additional mounting and adding accessories such as a microphone
