Litepanels Lykos+ Bi-Color LED Light $98 (Reg $549)
3 Min Read
Litepanels Lykos+ Bi-Color LED Light Panel
B&H Photo has a big discount on the Litepanels Lykos+ Bi-Color LED Light today in their DealZone. You can save more than $450 on the highly-rated panel that would be great when travelling.
Litepanels makes higher-end and reliable lighting equipment, and the discount on the Lykos+ should be hard to pass-up if you're in the market.
Purchase Options
Overview
  • Color 3200-5600K, CRI/TLCI: 96/96
  • Measures 10 x 6 x 2″, Dims 0-100%
  • Optional Bluetooth Module
  • AC or Optional NP-F Battery Power
With its compact 10 x 6 x 2″ form factor and color, light intensity, and power options, the Lykos+ Bi-Color LED Light from Litepanels is the perfect light for location or impromptu shooting. The Lykos+ has color temperature that's variable from 3200 to 5600K with a high CRI/TLCI rating of 96/96 – your assurance of advanced accuracy in color rendering.
The light is dimmable too from 0 to 100%, and while you can adjust the power and color on the fixture, you can also do it wirelessly via a separately purchased Bluetooth dongle. Other valuable features are the Lykos+'s power options. You can use the fixture worldwide with the included AC adapter, but it will also run on optional NP-F-type batteries when AC current is unavailable.
  • Lightweight, slim design with a handle on the side for precision adjustment
  • Color temperature and brightness dials at your fingertips next to the handle
  • Optional Bluetooth dongle supported for adjusting color and brightness via an iPhone app
  • 48 SMT LEDs (Surface Mount Technology), designed for improved optical efficiency
  • 96 CRI: high color accuracy
  • Over 2100 Lux max brightness at 3.3′ (daylight color temperature)
  • Adjustable color temperature: 3200-5600K
  • Flicker-free 0-100% smooth dimming with no color shift throughout the entire range
  • Color LCD display on the rear
  • L-Series battery mount
  • Two 1/4″-20 mounting threads are available: one on top, one on the bottom
  • Cold shoe for additional mounting and adding accessories such as a microphone
Purchase Options
Leave a Comment
Leave a Reply
