For today only, B&H Photo has on sale the Manfrotto Befree Advanced Aluminum Travel Tripod with Ball Head and Advanced Gear Backpack III Kit for only $219.90, saving you $160.
Key features include;
- Load Capacity: 19.8 lb
- Max Height: 59.1″
- Minimum Height: 15.8″
- Folded Length: 15.7″
- Leg Sections: 4
- Weight: 3.6 lb
- 494 Ball Head with Pan & Friction Knobs
- RC2 and Arca-Type Compatible QR Plate
- QPL Lever Leg Locks
- Advanced Gear M III 17L Backpack
Pairing a couple of travel shooting essentials, the Befree Advanced Aluminum Travel Tripod with Ball Head and Advanced Gear Backpack III Kit from Manfrotto provides added stability for your camera as well as an expansive pack for holding your gear. Included in this bundle is the Befree Advanced Travel Aluminum Tripod with 494 Ball Head and Lever Locks as well as the Advanced Gear M III 17L Backpack.
Manfrotto Befree Advanced Travel Aluminum Tripod with 494 Ball Head (Lever Locks, Black)
Sporting a 19.8 lb load capacity at a weight of only 3.6 lb, this black Befree Advanced Travel Tripod from Manfrotto is a robust support option that can serve as a convenient travel companion for professional photographers and passionate hobbyists alike. It is made of aluminum alloy and reaches a maximum height of 59.1″ with its column extended, folding down to 15.7″ in length for simplified transport in its included carrying case.
Each leg of the Befree Advanced is composed of four sections, which can be adjusted and securely locked into place with the QPL lever locks found on all segments. A side-pull selector allows you to set up the tripod at three different angle configurations, enabling low angle shooting with the simple push of a button. Complementing the legs is an equally sturdy center ball head, which offers a dedicated knob for panoramic movement as well as a friction control knob for precise control over the tension during use. The final element is a quick release plate, which offers dual compatibility for RC2 and Arca-type compatible systems, except for the Manfrotto 804-3W and MH804-3W tripod heads.
An Easy Link attachment is available at the top portion of the leg section, and allows you to connect compatible accessories such as flashes or reflectors. This enables you to use the tripod as a support system and reduce the amount of gear you need to carry while travelling. Rubberized feet are used to avoid skidding and help keep the Befree Advanced stable in most types of terrain. Finally, an integrated hook found at the bottom can be used to add a weight and increase the stability of your tripod when shooting in more difficult conditions.
