Pelican 1615AirTP Wheeled Hard Case with TrekPak Divider Insert System $349 (Reg $573)
1 Min Read
B&H Photo has the Pelican 1615AirTP Wheeled Hard Case with TrekPak Divider Insert System in their DealZone for $349.95 (Reg $573.95).
This iteration of the black Pelican 1615AirWD Wheeled Hard Case is designed for you to maximize its available space while providing customized protection for your valuable gear. You get the lined 1615 case with a divider system insert designed by TrekPak that allows you to customize the organization of your gear and update it as your gear changes over time.
Key Features
  • Waterproof, Crushproof & Lightweight
  • 29.6 x 15.5 x 9.4″ Interior Space
  • Made of Super-Light HPX2 Polymer
  • Updated Push-Button Latching System
  • Customizable TrekPak Divider Insert
  • Retractable Pull Handle & Wheels
  • IP67 Watertight O-Ring Gasket
  • Automatic Pressure Release Valve
Pelican 1615AirTP Wheeled Hard Case with TrekPak Divider Insert System $349.95 (Reg $573.95)
Leave a Comment
Leave a Reply
